Upper fairing bracket interchangeable?
Results 1 to 4 of 4
Thread: Upper fairing bracket interchangeable?
    Active Member
    May 2017
    Dallas
    Default Upper fairing bracket interchangeable?
    The part number for the 2008 is slightly different than the 2006. The 08 model number is 51850-48G00. I want to know if I can use the 08 bracket on the 06 model? The pic is the 06 bracket.
    Jun 2017
    Florida
    The model number for the 2008 model is 51850-48G10
    The model number for the 2006 - 2007 is 51850-48G00
    I am not sure what the difference is between these 2.
    The 2008-N model has a different model number yet to accommodate the R2D2 headlight. 51850-48GA0
    BCS
Name:	Bracket Model Number.jpg
    Very Active Member DutchM1800R2's Avatar
    May 2014
    Netherlands
    Between 06-07 and 08-onwards the turnsignal stay (chrome piece where the front turnsignals mount to) changed. 06-07 have two separate pieces, both left and right. 08-onwards has a single piece thats spans to both sides.
    Maybe they needed to change the bracket to accommodate for this new turnsignal stay?
    Active Member
    May 2017
    Dallas
    OK, I see the difference now. I probably can straighten my current one with some pliers or vice grips. The right side of the bracket is bent where the chrome turn signal holder mounts. I'm pretty sure I can bend or beat it back into shape because I refuse to pay $119 for a straight one. Thanks for the help because I thought all of them had 2 chrome pieces.
