bike not shifting
Results 1 to 26 of 26
Thread: bike not shifting
    Active Member RFM1009's Avatar
    Aug 2019
    Montana
    Default bike not shifting
    need your help again guys. ive got a new 2018 109 that wont shift all of a sudden. bike's only 3 weeks old and all of a sudden won't upshift past 2nd gear and is hard downshifting as well. any ideas. did i get a lemon? bike's only got 340miles on it.
    Active Member
    May 2016
    Virginia Beach Va
    Quote Originally Posted by RFM1009 View Post
    Clutch may not be adjusted correctly, clutch may not be fully disengaging hence making it difficult to shift.
    Aug 2019
    Montana
    clutch is fine
    Jul 2008
    Forney, TX
    Is there enough free play at the lower end of the clutch cable? If not that will cause it to be difficult to change gears also.
    Aug 2019
    Montana
    yes
    it'll shift 1st to second. just not 3rd and up. if im stopped i can manually pull up on the shift lever and get it into 3rd, 4th, 5th. but it takes alot of effort. and it cant be be good on the shifter to pull on it that hard.
    Aug 2017
    uk
    bent selector fork maybe ? a hell of a mission if it is !
    does it shift ok with the engine off ?
    Aug 2019
    Montana
    Quote Originally Posted by frankj View Post
    bike's brand new. should be covered under warranty
    Aug 2019
    Montana
    won't shift with engine off.
    Aug 2017
    uk
    as long as they dont accuse you of bending it eh
    Aug 2017
    uk
    bent fork looking more likely if its hard to shift with engine either on or off then
    May 2019
    Don`t do anything , disassembly or otherwise . Take it to the dealer you bought it from . The have to fix it if it is a new bike , no question .
    Aug 2019
    Montana
    Quote Originally Posted by josey088 View Post
    dealer is 80 miles away. and i can't really ride it is the problem.
    Feb 2009
    Oklahoma City
    U-Haul rents trailers with a chock for a motorcycle front tire. You're going to have to get it there somehow.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Aug 2019
    Montana
    I have another Suzuki dealership only 20 miles away(not where i bought the bike). they're gonna tow it for me. I've never dealt with them before. hopefully they know what they're doin.
  17. #15
    Nov 2015
    Keep us posted on the situation with your bike. Good luck with Suzuki.
  18. #16
    Aug 2019
    Montana
    Quote Originally Posted by Metalman View Post
    thx guys. talked to the dealer today. they're gonna come get it tomorrow or fri.
  19. #17
    Aug 2019
    Montana
    dealer contacted me and said bike is fixed. said it was a bent shift rod. probably from an impact. no impact to speak of. been pretty much babying the bike since I've had it. haven't hit anything or laid her over. but at least it's fixed. or so they say. won't be able to pick it up and check for sure til Tue. we're gonna see. anxious to ride her though. only had 330mi on it before this issue. will keep you updated...
  20. #18
    Aug 2017
    uk
    ours is a constant mesh dogbox, so "shifter rod" sounds strange
    to fix it that quick suggests the found something bent on the shifter star mechanism maybe ?
  21. #19
    Jun 2006
    Indianapolis, Indiana
    That would be the shift rod between the foot lever and the pivot arm on the left side lower of the bike. Not inside the engine. This has happened to a few that I have fixed. I was going to suggest this, but obviously late to the conversation.
  22. #20
    Aug 2017
    uk
    why would it only affect 3rd 4th and 5th tho ?
  23. #21
    Aug 2019
    Montana
    here's the text i got from the dealership. open to interpretation im sure
    RYAN
    We have completed the repair on your motorcycle..The shift linkage was bent & binding on the bottom of the case..We straightened the linkage & made the necessary adjustments.The total is $292.00..You can pick it up at your convenience..We will be closed till Tuesday..
    SEAN WARD
  24. #22
    May 2019
    That remind me of something that happened to me some time ago with my Indian Chieftain … I bought a set of floorboards from Kuryakyn for the bike and when I installed them , I started to have problems shifting to 2nd gear . I called the dealer and made an appointment and two days later I went there . It turns out that the Kuryakyn floorboards are much thicker than the factory floorboards so it were interfering with the linkage . It took the dealer mechanic 10 minutes to fix it and they didn`t even charged me for it .
    I am surprised that a brand new bike with such a little issue the dealer will charge $292.00 for it and would not add it to the warranty … just saying !!!
  25. #23
    Aug 2019
    Montana
    believe me i know. they also said the repair was about 4weeks out(busy shop). so getting it fixed in a few days was nice. but yeah, it still sucks im out nearly $300 for something that totally should be a warranty issue.
  26. #24
    Very Active Member Andy33's Avatar
    Jan 2010
    Calgary, Alberta
    Any update on this?
    Have you ridden the bike much after the fix? I have a shifting concern and am hoping maybe its a quick fix like this?
    Curious if you have photos of what was replaced exactly?
    2009 M109 LE
    ISO grips, Swing Wing pegs, Shifter/Brake pedal MOD, Rivco 2" Risers, V-Stream Windshield, Cobra Sissy Bar/Rack, Tach Relocated, Mini Bullet Signals, Scythe 2 Mirrors, Debadged, DeBeaved,
    RaceTech fork Springs, Progressive 465, LA Choppers 2" bones, Cycle House Kickstand, Chrome Stock Wheels, Freedom Exhaust, Goldwing Intake MOD + K&N filters, Cobra Power Pro
  27. #25
    Aug 2019
    Montana
    Quote Originally Posted by Andy33 View Post
    Any update on this?
    bike shifts great now. they said it was a bent shift rod. no photos sorry
  28. #26
    Member Deep9's Avatar
    Oct 2015
    Ocala, FL
    I hit a deer Saturday. He caught my left signal and the bottom of my foot. That drove the top of my foot into the shifter. Shifts up ok, missed 2nd for the first time ever. 2007 bike I’ve had since 2015. Sometimes shifting down is tough and I’m pretty sure the shifter is not where it was before. Almost like the rod was stretched.
    Sent from my iPad using Tapatalk
