Efi controller, new exhaust
Results 1 to 2 of 2
Thread: Efi controller, new exhaust
    Default Efi controller, new exhaust
    Ok I ordered a set of 2.5” street lights. I’m looking for a efi controller now. I’ll probably go with Dynojet I’ve had good luck with them on my drag bikes. What I’m confused about is will removing the exhaust servo cause issues by just unplugging it? Does this valve open after a certain rpm?
    I’ve ordered the exhaust but still need to order the controller and crush washers. Any advice would be greatly appreciated. I’ve only had this bike a couple weeks. Thank you
    Jun 2018
    Concord, VA
    You might think about an ECU flash. It would save you some money. Here is some info on the exhaust. BCS in the link below would be the one to contact if you want info on flashing the ECU.
    Exhaust servo eliminator? https://www.m109riders.com/forums/sh...d.php?t=346908
