Beaver-Free turn signal custom mount
Thread: Beaver-Free turn signal custom mount
    Active Member Luap's Avatar
    Jun 2019
    Central NY
    Default Beaver-Free turn signal custom mount
    Well... removing the beav is nothing new but it does create a small problem because integrated tail lights aren't exactly the best and most visible way to signal your intentions to depart the current highway. Friends tell me on sunny days they can't even see my integrated signal when it's on. So, I started thinking about how to get around that little problem without messing up my clean rear end, and I think what I came up with is pretty darn good.
    So the thing is I never plan on putting bags on my BOSS, just not my bag, so if you have noticed the rear bolt has a nut and just comes right out leaving a nice mounting hole for turn signals. Well I got my slide rule out and cross checked things with my protractor and TI pocket calculator and by golly this could actually work.
    I checked the threads on the signals I had already bought (for the front, but they sent a 4 pack so I had 2 leftover). They are metric ... 10mm x 1.5 pitch. Well wouldn't you know it the hole just happens to be the perfect size to run that tap through. So I tapped both sides and after screwing in the signals, I used the nut screwed on backwards as a jam nut against the frame of the bike. Perfect, it holds the bag mount cover just like the bolt and nut did, and the one in the front is on nice and tight too.
    Now if I ever did want to put bags on, the fact that I threaded the hole won't matter a bit. I consider this mod a win win. Looks great, BOSS themed, works perfect, increased visibility and safety, all with no downsides.
    Disclaimer - I haven't seen anyone else take this approach, but if you did, sorry I didn't know. I did search the board.
    Here are some pics to show how it went
    . Click image for larger version.
ID:	384882Click image for larger version.
ID:	384884Click image for larger version.
ID:	384886Click image for larger version.
ID:	384888Click image for larger version.
    2019 M109R B.O.S.S. red/black
    MODS: LED signals, Integrated tail light, Luap hole-saw mod, axle mounted plate, no beaver, carbon fiber look tank bra, dual air horn, black spiked grips, "bar end key" mod, drink holder :), more to come
    Jun 2019
    Central NY
    rest of the pics
ID:	384892   Click image for larger version.
ID:	384894   Click image for larger version.
ID:	384896   Click image for larger version.
ID:	384898   Click image for larger version.
    Jun 2019
    Central NY
    These are the blinkers I chose. The relay was supposed to be here yesterday but it's late - should be here tomorrow
    blinker link: https://www.amazon.com/gp/product/B07PJJ9CXD
    Thread: metric 10mm x 1.5
    Good job on that turn signal mod Luap.😊👍 Not to diminish your accomplishment, but it has been done by several members in the past, using a variety of turn signal styles. Each style gives the bike it’s own unique look/spin, which looks very good...especially when the turn signals blend/flow with the scheme of the bike.
    GREAT JOB!!!
    same as above. I did it too. Removed it 5 minutes later because it looks like Yoda's ears lol Went with the Revo LED strip
