Turns over not starting/06 M109R
Results 1 to 4 of 4
Thread: Turns over not starting/06 M109R
    Jun 2006
    Default Turns over not starting/06 M109R
    I’ll say this first, I crank this MC about once a month, haven’t in while, not riding, a lot, The last time was a month or so ago. Starter is turning, caught a couple times briefly. Haven’t seen any warning lights, just not starting, any thoughts? Thanks in advance.
    Jun 2017
    Florida
    Have you had the tank off for any reason?
    Very common to forget to plug in the brown electrical connector for the fuel pump or to pull a wire in this connector loose when unplugging it.
    You will get similar symptoms to what you describe if this is the case.
    Also charge your battery to 100% with a smart charger, the 9 does weird things when the battery is low.
    (I know you say it turns over but check the battery anyway.....I would not be surprised if this is the problem if you have not had the tank off)
    Also maybe a bit obvious but.....you do have fuel in the tank?
    BCS
    Very Active Member majalomalk's Avatar
    Feb 2017
    Birmingham england
    I would look at the battery first as bcs said may crank but wont start if low
    Active Member Luap's Avatar
    Jun 2019
    Central NY
    Long shot here, but you said it mostly sits around, maybe the gas is bad. If you open the cap and sniff does it have a rotten egg smell?
    2019 M109R B.O.S.S. red/black
    MODS: LED signals, Integrated tail light, Luap hole-saw mod, axle mounted plate, no beaver, carbon fiber look tank bra, dual air horn, black spiked grips, "bar end key" mod, drink holder :), more to come
