FI Light and C00
Results 1 to 9 of 9
Thread: FI Light and C00
    Default FI Light and C00
    I just picked up a 2008 M109R today with 2600 miles. It has the Cobra swept exhaust with a Cobra FI2000 tuner. The FI light is lit, but when I checked the codes, it was clear. What next? Thanks in advance.
    Dec 2016
    Saskatchewan Canada
    Possibly the exhaust servo is disconnected or taken off and there was no Exhaust Servo Eliminator installed.
    Jun 2017
    Florida
    If the FI light is on try starting the bike and then installing the jumper and see if it shows you the actual fault code.
    If it does not then only turn off the red kill switch and not the key and see if it then gives you the fault code.
    Each time you turn off the key it resets the fault codes so the FI light must be illuminated when you try to pull the code.
    BCS
    BCS
    Ok, I'll have to try this. Thanks.
    Got a code C46. Servo, I'm assuming?
    Jun 2017
    Florida
    Quote Originally Posted by Mxboost View Post
    That is correct it is the code for the exhaust servo.
    FI light code key:
    C00: None - No defective part
    C12: Crankshaft position sensor (CKPS) - Pick-up coil signal, Generator
    C13: Intake air pressure sensor #2 (IAPS #2) - For Front cylinder
    C14: Throttle position sensor (TPS) - (Note *1)
    C15: Engine coolant temp. sensor (ECTS)
    C17: Intake air pressure sensor #1 (IAPS #1) - For Rear cylinder
    C21: Intake air temp. sensor (IATS)
    C23: Tip-over sensor (TOS)
    C24: Ignition signal #1 (IG coil #1.1) - For Rear cylinder
    C25: Ignition signal #2 (IG coil #2.1) - For Front cylinder
    C26: Ignition signal #1 (IG coil #1.2) - For Rear cylinder
    C27: Ignition signal #2 (IG coil #2.2) - For Front cylinder
    C28: Secondary throttle valve actuator (STVA)
    C29: Secondary throttle position sensor (STPS) - (Note *2)
    C31: Gear position signal (GP switch)
    C32: Injector signal #1 (FI #1) - For Rear Cylinder
    C33: Injector signal #2 (FI #2) - For Front Cylinder
    C40: Idle speed control valve (ISC valve)
    C41: Fuel pump control system (FP control system) - Fuel Pump, Fuel Pump Relay
    C42: Ignition switch signal (IG switch signal) - Anti-theft
    C44: Heated oxygen sensor #2 (HO2S #2) - For E-02, 19, 24
    C46: Exhaust control valve actuator (EXCVA)
    C49: PAIR control solenoid valve #2 (PAIR valve #2) - Except for E-03, 28, 33
    C60: Cooling fan control system - Cooling fan relay
    C61: PAIR control solenoid valve #1 (PAIR #1)
    C64: Heated oxygen sensor #1 (HO2S #1) - For E-02, 19
    Will removing the #7 pin from the ecu clear the code?
    Jun 2017
    Florida
    Yes it will stop the FI light from coming on due to this fault. (Not 100% on the terminal designation though so double check that)
    Or you can put a ESE in place of the OEM servo module.
    BCS
    Ok. Thanks BCS. I'll double check the pin, and try that.
