Hole Saw stuck in exhaust.... HELP
Results 1 to 18 of 18
Thread: Hole Saw stuck in exhaust.... HELP
    Active Member Luap's Avatar
    Jun 2019
    Central NY
    Default Hole Saw stuck in exhaust.... HELP
    Ok let's preface this by saying how dumbtarded I feel for this but....
    I got a 1-1/4 hole saw and 20" 3/8 extension and used a socket to drive the hole saw. Well it was working fine, got the first plug out, went back for the second one, and now the hole saw won't pass back through the first hole
    I've tried a bunch of stuff and I can't get it out
    My next attempt will be to try and superglue the hole saw to the socket
    Anyone got any better ideas??
    Signed
    Ashamed and frustrated
    Jun 2017
    Florida
    I realize this is slapping at the horse after its left the gate but.......you would be better off using a proper hole saw extension that has set screws to lock the hole saw arbor tightly in place.
    https://www.amazon.com/Lenox-Tools-3.../dp/B0002438KI
    To get the hole saw out out now you may need to get a strong magnet on a stick to catch the end of the arbor and guide it out.
    You may have to remove the exhaust and hang it up so the mufflers are pointed down, that way gravity is working with you and not against you if you don't have any luck getting it out with the pipes mounted on the bike.
    BCS
    Jun 2019
    Central NY
    BCS
    The right tools are so important, and now I'm paying for my impatience
    I'll give it another go tomorrow. New day
    2019 M109R B.O.S.S. red/black
    MODS: LED signals, Integrated tail light, Luap hole-saw mod, axle mounted plate, no beaver, carbon fiber look tank bra, more to come
    Apr 2014
    Chesterfield, VA
    Enlarge the outer hole slightly with the next size up to make it easier to get the first bit out.
    Seems like the perfect excuse for an aftermarket exhaust if you were on the fence about going that route instead.
    Jun 2019
    Central NY
    Not sure it will fit anything larger, but I do have a step grinder bit that may do that. Good idea, thanks
    Feb 2009
    Oklahoma City
    Sanding drum or rotary file will make the hole slightly larger.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Active Member Sneikz's Avatar
    Jun 2018
    Kirrawee, NSW, Australia
    And what was the outcome?
    Sent while not riding
    Live long and ride hard \\ //
    Jun 2019
    Central NY
    Quote Originally Posted by Sneikz View Post
    I'll find out today. I applied my "JB Weld" mod last night and am letting it cure until after work
    I'll post up the results, hopefully good ones.....
    Jun 2019
    Central NY
    Well the JB Weld did not stick ... I was not able to get the hole saw out. However after I thought about it it's no different than having the baffle plate in there in the first place and it doesn't rattle so I'm just not going to worry about it I guess. I'll almost certainly put pipes on it next year. Lesson learned
    Apr 2014
    Chesterfield, VA
    Quote Originally Posted by Luap View Post
    Need to add one of a kind, performance hole saw exhaust baffle to your mod list in your signature.
    Like I said earlier in the thread, perfect excuse to add aftermarket exhaust!
    Jun 2019
    Central NY
    This LITERALLY made me lol
    Nov 2015
    Are you turning the hole saw either forward or reverse as you gently attempt to pull it back out? Must be a folded burr on the opposite side of the hole. Using a dog-knobbed, rat tail file extension, can you file the edges of the offending hole?
    Jun 2019
    Central NY
    Quote Originally Posted by Metalman View Post
    I can't get anything up in there to de-burr or grind out the hole. I've resigned myself to it being a "mod" at this point, and it's not really hurting anything. New pipes next year anyway
    Apr 2014
    Chesterfield, VA
    I like the new signature!
  17. #15
    May 2016
    Maine
    Default Maybe this will work?
    Signed
    I'm not sure I understand what your situation is but, maybe try using heat to expand the pipe while trying to remove hole saw. Either a blow torch not good on chrome or a serious heat gun. Also somehow, putting door lock graphite inside to lubricate the pipe?
    Good luck!
  18. #16
    Dec 2016
    Saskatchewan Canada
    Cut them off and go Scorpion Tips
    https://www.meancycles.com/store/par...?partID=215232
  19. #17
    Jun 2019
    Central NY
  20. #18
    Jun 2019
    Central NY
    Hey I like those. No baffles I assume tho. I"ll have to look into them
