Rear wheel install grease?
Results 1 to 10 of 10
Thread: Rear wheel install grease?
    Active Member Gofasttoys's Avatar
    Jul 2015
    Michigan
    Default Rear wheel install grease?
    Just replaced my tire. Do I need to use special Suzuki grease on the drive side? Or just a skim coat of wheel bearing grease okay?
    Apr 2006
    Traveling America
    Quote Originally Posted by Gofasttoys View Post
    Do you mean on the axle? If so yes, good wheel bearing grease is what you should use. I used Mobil 1 synthetic grease. Clean it first also.
    Coming to a city near you..
    Jun 2017
    Florida
    Sounds like he is talking about putting grease on the splines of the driven joint on the rear wheel.
    Suzuki does spec adding grease to the splines of the the final gear before installing the rear wheel.
    Of course the manual is referring to after rebuilding the final drive, but it certainly cannot hurt to keep the splines of this gear greased.
    You will also want to put a thin layer of grease on the axle before installing it as Ryan pointed out.
    See print screen from manual below.
    BCS
    Apr 2006
    Traveling America
    BCS
    I think I used a Molly lube where you are talking bout, if I remember correctly.
    Jul 2008
    Forney, TX
    BCS
    If he is talking about that final drive inner gear, I used Molly lube. Just use a little because it will sling out the excess all over the rim.
    Dec 2016
    Saskatchewan Canada
    I grease mine every spring when I replace my tire. I wipe the existing grease off and then reapply new grease. Use a high temp wheel bearing grease
    Nov 2015
    I Honda Moly 60, which is specified for Hondas with shaft drive. It's expensive for a small tube, but it will last for years. Once you lube your finger to spread the grease, it's a bugger to wipe clean.
    Apr 2006
    Traveling America
    Quote Originally Posted by Metalman View Post
    Yes it is very pricey stuff.
    Active Member
    May 2019
    Sagle, Idaho
    I used this on the driveshaft and wheel splines of my Rocket III. Plan on the same with the 9 when I change tires.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    MoCo Maryland
    This, right here
