Just sharing my experience
Results 1 to 6 of 6
Thread: Just sharing my experience
    Active Member
    Jan 2019
    Barrie,ON
    Default Just sharing my experience
    Just sharing my experience in the last few days.
    Whom seen my older post from a few days a go I made a rookie mistake and f up my drain plug(only the rear).
    So went out there to look for the best "kit" to fix it.
    New pan is about 226CAD +TAX from the dealer
    There quite a few kits out there to repair stripped threads(helicoil)but the one I end up used is made for spark plugs.
    The kit is basic and straightforward
    First used the tap to retap the original hole with a good amount of grease so all shavings will stick in it,the tap have 2 steps,the second step is the actual thread for the helicoil,but instead of going all the way in,I did it step by step 2-3 thread at the time,pulled the taped out cleaned the dirty grease with the shavings,regrease and in again.
    After a few times the thread in nice and clean,all the way.
    Put some harder gasket on the helicoil and in
    The last tool it's to punch in the coils and all done
    Sorry for the creepy English.
    Sent from my SM-N960W using Tapatalk
    Apr 2017
    Ontario, Canada
    WHEW, right??
    Glad that worked. Hopefully it holds.
    Good to know for if I ever do the same.
    Nov 2015
    Thanks for the info. I will try to find this thread if I have the same problem. It would help if the tread titles matched the content.
    Dec 2016
    Saskatchewan Canada
    Glad it all worked out for you. Hoping I never have that problem but one never knows
    Very Active Member W8INLINE's Avatar
    Aug 2015
    Canada
    Where did you get that kit from?
    <img src=https://www.m109riders.com/forums/signaturepics/sigpic65778_1.gif border=0 alt= />
    Active Member
    Jan 2019
    Barrie,ON
    Quote Originally Posted by W8INLINE View Post
    Amazon.ca
    Helicoil 5334-14 Save-A-Thread Thread Repair Kit M14 x 1.25 https://www.amazon.ca/dp/B0002SRF4O/..._x31hDbM6Z0V9E
