Accessory line to splice into
Results 1 to 6 of 6
Thread: Accessory line to splice into
    Default Accessory line to splice into
    I have a C109r and need to tap into an accessory line for power so my radio will turn off when I shut off. How do I find it?
    Very Active Member BIGSTUF's Avatar
    Nashville, TN
    I have seen several posts that recommend tapping into the running signal of the tail light or front blinkers.
    Nov 2008
    Newmarket, Ontario
    I would recommend getting a fuze block
    http://www.motorcyclelarry.com/index...roducts_id=404
    Then you isolate your accessories. Tap from battery and ignition.
    If you tap from signal light, and you blow a fuze, you no longer have back brake and signal lights or speedo....dangerous situation.
    Very Active Member Acquitted's Avatar
    Jul 2015
    Akron, OH
    Quote Originally Posted by BradSmith View Post
    +1
    Wire directly to the battery, and use an inline fuse. That's how I wired my air horn.
    2008 C109RT - ISO grips, K&N Air Filter, NOS exhaust and filter housings, rebuilt driver seat.
    Hammertone powder coat on fenders and tank.
    Plastidip rear frame, sissy bar, side frame covers, and windshield hardware.
    ........yes this for sure.
    Exactly how I have all the assorries on my bike wired up.
    The fuzeblock keeps everything isolated and individually fused and you have the choice keep each circuit "hot" all the time or have each circuit individually energize when the ignition is turned on. You select this simply by where you plug the fuse for each circuit into the buss.
    The fuzeblock keeps things nice and tidy in one place so you don't have a lot of individual fuses floating around on your bike.
    Tapping into your wiring harness all over the bike is never a good idea, it rats up your bike and eventually becomes a troubleshooting problem if you do.
    Very Active Member 06MrMike's Avatar
    Jun 2006
    Westmore, VT
    so i have a fuzebox im looking to install. Im told there is a wire (grey) under the seat that i should tap into for the switched source of power. Does anyone have any pics of said wire?
    Mike
