Hey y’all! Just curious what the knowledge bank here can tell me about the pros and cons of a exhaust servo eliminator for a 2018 M109R BOSS? And if it’s worth doing what’s the one to buy?
Thanks in advance for any help.
If you install a aftermarket exhaust you will need a ESE (exhaust servo eliminator) in order to keep from throwing a FI fault.
This is not a performance part and does nothing to make the bike run better, so there are no pro's & cons.......you either need one or you don't.
If you still have the stock pipes on the bike then you don't need a ESE unless your exhaust servo goes bad and causes a FI fault.......which in that case you could get rid of the exhaust servo and install the ESE to cure the FI fault that would be active.
BCS
Here is the link to the one I use.
https://www.meancycles.com/store/par...?partID=222600
BCS
I got the Healtech one but the Revo would do the same thing
I picked up the Servo Buddy from eBay and FI light has yet to come on. Really can’t go wrong with any of the listed name brands as they all do the same thing.
