Paint YKY
Results 1 to 9 of 9
Thread: Paint YKY
    Default Paint YKY
    Good morning all,
    I searched the forum about this before asking and came up with nothing, so now I must ask.
    I own a 2017 M109R BOSS, the main paint color is code YKY and is called Pearl Vigor Blue.
    I recently noticed that my front fender is split in half, I added a flood light to the front for night driving and I did not realize how much travel their was in the front forks. Anyway the light smashed into the fender enough times or hard enough to break the fender.
    I purchased a new one used and it is bright orange. I would like to repaint the fender but all the color match paints are WAY WAY expensive.
    I have tried to cross reference the code to see if the paint is produced or used by another manufacturer like Ford or Mopar in hopes of finding out if this same color is mass produced and readily available as a different name.
    Has anyone had any success with this? Do you have suggestiins other than repaint the bike? Your help is greatly appreciated.
    Nov 2009
    San Antonio, TX
    P, is absolutely correct in recommending www.colorrite.com. They are practically the only company I know of that supplies the OEM M109R bike colors. You would be wise to go with his recommendation, to insure your newly painted part is a direct match. Your paint is not something you want to cut corners on.
    Below I have provided you with the link to exactly what you’ll need from colorrite to get your new front fender color-matched to the rest of your bike.
    https://www.colorrite.com/product/su...-blue-1738.cfm
    Very Active Member Blackey's Avatar
    Sep 2012
    Seattle
    Quote Originally Posted by Huskarl View Post
    Good morning all,
    Just wanted to mention...I have a black front fender from a 2009 if you are interested. Would let you have it for the cost of shipping/ Lemme know if interested
    09 "Blackey" - Swept, Engine Case Guarded, Derby'd, Iso Gripped, Badged, Boned, De-Shuddered, Beavered, Risen, Cabled
    I appreciate the information. Looks like I will have to go with Colorite.
    As for the black fender, thank you. I already bought another is blazing orange.
    So off to the races.
    Thank you again for the assistance.
    Jan 2009
    Hampton, Ga
    Get a can of silver. Sand the orange paint, spray it silver first. It'll help cover the orange and the blue won't be as dark and it'll match the rest of the bike better.
    -Josh
    Mar 2013
    Calgary, AB
    I'd sand it and then prime it with a tinted primer, you could just use a light gray primer to save costs, and then paint it. If you are going to do it by yourself try to make sure there is no static electricity on the fender before you paint it. It helps with the metal flake in the paint to lay down properly. Good Luck
    Apr 2015
    The Rose; Central Alberta
    My dealer recommended these guys to me. I'm not sure how the price compares to ColorRite but the shipping was fast.
    https://touchupdirect.com/?gclid=Cjw...BoCFekQAvD_BwE
    Nov 2009
    San Antonio, TX
    Quote Originally Posted by meierjn View Post
    They’re much more expensive than colorrite.
