280 on a 10" rim
Results 1 to 22 of 22
Thread: 280 on a 10" rim
    Very Active Member DivkoviC's Avatar
    Jul 2008
    Ontario Canada
    Default 280 on a 10" rim
    Do I need to do any modification to make this fit or would I be able to just swap the rims and tires?
    Very Active Member MR.X's Avatar
    Mar 2010
    L'Islet, Qc, Canada
    no mods needed. Try to drop air in the tire when installing/removing get things easier to process.
    Very Active Member Viper109R's Avatar
    Apr 2012
    Iowa
    i would ad to this question where to buy a 10 inch rim...and does it change the profile of the tire compared to an 8 inch rim?
    2007 M109R | Smoked Tail | Debeavered | HardKandy 3" Drag Pipes| HID | Mini Turns
    Apr 2014
    Chesterfield, VA
    Quote Originally Posted by Viper109R View Post
    Coastal Moto is where I got mine. You can also find them at MeanCycles. A 280 tire on a 10” wheel will have the same side wall profile as a 240 on an 8.5” wheel. 300 on a 10” wheel will have the side wall profile as a 260 on the stock wheel.
    Aug 2013
    Gardner, KS
    Quote Originally Posted by DivkoviC View Post
    The 280 and 10'' rim will fit the stock swing arm without any modification. However, You will need to remove the rotor, caliper and even exhaust depend on what pipes you have to get it in. You have to start the wheel at a 90 degree angle to the rear of the bike with the swing arm over the hub in the barrel of the wheel. Being careful not to scratch anything you will then roll the rim strait into the fender area and lower the bike down to meet the rim to reinstall the axel and brakes. Its a tight fit so take your time and cover the swing arm with old towels to prevent scratches.
    BOTM: SEPT 2016
    Jul 2008
    Ontario Canada
    Quote Originally Posted by Mrtallguy67 View Post
    Thanks for the advice. I should be installing it this weekend.
    Also, will being lowered 2" cause any necessary modification to the fender? Or is this another problem that only arises when going to the 300
    Apr 2014
    Chesterfield, VA
    If you are lowering it, grind off any bolts that extend below the inner fender. They will only be an issue if the suspension if fully compressed, but the bolts, if left, could slice through the tire.
    Feb 2009
    Oklahoma City
    One thing I noticed when I went with the 10 inch/280 combo using a Metzeler 280. With the stock rim and a 250 Dunlop Elite, I was never able to get wear on the tire all the way over to where the tread meets the sidewall. Just couldn't do it. Now, with the Metzeler, riding the exact same as I always have, the wear goes all the way across the entire tread section. To me, that tell me it's a little flatter than the Dunlop. Bike handles great and it doesn't feel like it takes more effort to lean it over hard.
    Also, on the front. I went Metzeler 140/70. Now, with the Dunlop Eite III 130/70 on the front, I had wear all the way across the entire tread, unlike the rear. Now with the Metzeler, it's the opposite. Unable to get wear across the entire tread.
    So to sum up, rear tire wears all the way across, where with the stock set up I couldn't do it. Front tire does not wear over the entire tread, where with the stock set up it would.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Aug 2013
    Gardner, KS
    That or you can shim it with washers on the top side of the bolt rather than grinding, either way will work.
    BOTM: SEPT 2016
    Jul 2008
    Ontario Canada
    It's already lowered so maybe done already but I will see the bolt situation once I take the stock rims off, thanks
    Jul 2008
    Ontario Canada
    The front rim has a 160 on it, so I'm curious to see how that will handle.
    Might as well ask this question here too.
    Will a 160 on the front require any modification?
    Aug 2013
    Gardner, KS
    Some say yes, some say no. I have a 160/300 set up now and was on a 280 in the past. I have LED's under the fender, so I made a set of fender extenders for my bike to be safe. I have also installed 160's for friends that didn't run any extenders so it could go either way. Basically if a rock gets stuck in the tread it will tare up the fender. You can loosen the fender bolts and use a rat tail file to slightly oblong the mounting hole and have another person pull up on the fender while you tighten the bolts back down as a cheap fix. Or grab a set of extenders from meancycles.com or if your handy make your own. The way I look at it is the extenders are a lot cheaper than a fender and I'm better safe than sorry.
    BOTM: SEPT 2016
    Apr 2014
    Chesterfield, VA
    Better safe than sorry.
    Jul 2008
    Ontario Canada
    Ok, sounds like I'll be able to put it on and ride but will definitely get some fender extenders on order just in case
  17. #15
    Very Active Member W8INLINE's Avatar
    Aug 2015
    Canada
    Interesting observation on the ware of the 280 vs the 250. Could it be that the metzlers are stickier than the dunlops and therefore you lean them more? I thought the 250's are flatter on in the middle than other sizes/brands out there hence the longer life they get.
    After reading this I see a 10"rim with a 280 in my future
    <img src=https://www.m109riders.com/forums/signaturepics/sigpic65778_1.gif border=0 alt= />
  18. #16
    Feb 2009
    Oklahoma City
    Quote Originally Posted by W8INLINE View Post
    Like I said, I don''t ride any different. With both tires, I was hitting my heels on the ground on curves, followed by the peg feelers very lightly touching. I think the 250 when mounted on a stock rim, has more curve than the 280 does. And it's just hard to get over that last little bit to get all the way to the edge. I guess, if you're into scraping more than just the feelers, you may be able to do it.
    All I'm saying is that without changing my riding style one little bit, the 280 is worn all the way to the edge. Never could do that with the 250. Mikey likes it!
    The 140 Metzeler front has a lot more curve to it than t he Dunlop 130 did. Hence I'll never be able to wear it to the edge like the 130 did.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  19. #17
    Feb 2009
    Oklahoma City
    You don't need extenders. The 140 I run up front is taller than those 160's. Just go to your nearest hardware store and pick up some bolts and washers to replace the stock fender bolts. The stock bolts have a large shoulder on them. That shoulder fits in the fender holes. If you install bolts without the shoulder and use washers to sit them on the fender, you'd be amazed how much movement the fender has. I love the way my fender hugs the 140 front tire, no big gap any more. But enough clearance to prevent a stone tearing up the fender.
ID:	384124   Click image for larger version.
ID:	384126   Click image for larger version.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  20. #18
    Apr 2014
    Chesterfield, VA
    280 Metzeler definitely wears all the way to the edge. When you ride hard in the twisties, you end up with cat whiskers on the edge of the tread where it is rolling off the tire.
  21. #19
    Feb 2009
    Oklahoma City
    Yeah, I was wondering what exactly would happen if you went too far. Since I never could on the 250, it never entered my mind. Then I get the 280, and first ride on my favorite set of curves, it's all the way to the edge. I'm like, Geeze, what happens if I lean just a little further? I guess it doesn't just slide away from you, seeing your tire.
    No more chicken strips, now we have cat whiskers. LOL!!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  22. #20
    Apr 2017
    Ontario, Canada
    I was nervous about clearance (shocked the 140 fits?!) and did this for my 160, working beautifully:
    https://www.m109riders.com/forums/sh...d.php?t=346302
  23. #21
    Feb 2009
    Oklahoma City
    I'll have to check my fender this weekend. I don't see evidence of it around the holes. Been this way with the different bolts and washers since July 18. Almost 4000 miles.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  24. #22
    Apr 2017
    Ontario, Canada
    Ya, I was quite shocked too - did the M6 bolts and washers one day, went for a ride, then found the fender the next morning all splintered and cracking under and around the bolts. Mildly freaked out, made those washers, all good now.
