spark plug question
Results 1 to 7 of 7
Thread: spark plug question
    Sep 2015
    Prince George BC
    Default spark plug question
    removed my spark plugs today and noticed that the plugs that are in the centre of each cylinder have the 2 side prongs pointing to the electrodes and the plugs that are on the outside of the cylinders have only an electrode....Click image for larger version.
    Is this correct? Are the 2 outside plugs really worn out?
    T.I.A.
    Dec 2016
    Saskatchewan Canada
    Look at the part number on the plugs. They should all be the same and the ground points should all be one on each side. If it's the first time you've changed them then previous owner screwed up and replaced 2 thinking there was only 1 plug per cylinder
    The ones with just one ground could be iridium plugs
    The proper ones are CRE8K
    Sep 2015
    Prince George BC
    2 are a brand named Brisk, premium AR1225, the other 2 are NGK CR7EK
    Dec 2016
    Saskatchewan Canada
    Quote Originally Posted by ginjerking View Post
    the NGK CRE7EK are factory plug. the CRE8EK are just hotter plugs of the same thing, The Brisk are probably Iridium versions. SOme have had issues with Iridium and some love them so you just have to see what you think if you install them. The reason they would be different in your case is whoever changed them last didn't realize there are 2 per cylinder. Were the Brisk ones on the outside easy to get at ones?
    personally I use the NGK CRE8EK or 7s are fine too
    Sep 2015
    Prince George BC
    lol, yes they were......I'm thinking the NGKs are original
    Dec 2016
    Saskatchewan Canada
    Depending on year could be original.
    I wish there were only the 2 easy ones LOL
    When I got mine from dealership for my 2012 it came up as the CRE8EK and they just are a hotter plug so you'd be fine with 7 or 8
    Sep 2015
    Prince George BC
    Thank you for clearing this up, new plugs tomorrow
