motorcycle lift
Results 1 to 12 of 12
Thread: motorcycle lift
    Active Member LuckyLuke's Avatar
    Apr 2019
    Default motorcycle lift
    Do you have any recommendations for motorcycle lift/stand?
    Nov 2014
    Southern Indiana
    Quote Originally Posted by LuckyLuke View Post
    I have the J&S motorcycle lift. Has worked great so far.
    https://jsjacks.com/product/motorcycle-lift/
    Apr 2019
    Quote Originally Posted by Kratos109 View Post
    I’ve just seen video where they compare cheap one from harbor freight, one from pitbull and also J&S. J&S was best of all. But the price for it is around $600 and I’m not sure if I can afford that right now.
    Jun 2018
    Concord, VA
    A friend has one he got at Harbor Freight and I use it often. He uses it for his Indian Chief.
    Very Active Member Weedahoe's Avatar
    Aug 2014
    Albany GA
    I had had for years the lift table from Harbor Freight and I have jack from Sears/Craftsman
    Member alx109's Avatar
    Apr 2019
    Tampa
    Default kendon lift best air and manual lift
    air powered or manual lifts my bike up with ease. Also available accessories like oil catcher and in rail jack
ID:	383830   Click image for larger version.
    Nov 2008
    Newmarket, Ontario
    I have a 1000lb lift with front chock and the back has a false bottom to remove for changing rear tire.
    Pneumatic lift.
    Princess Auto, $700 CDN.
    Apr 2017
    Ontario, Canada
    If you are in Canada, or find something similar, I am perfectly happy with this at $129 CAD on sale, except you can't do oil changes with it, which ironically was a primary reason for me originally buying it. Didn't really think it through. Ha.
    https://www.canadiantire.ca/en/pdp/m...-0091015p.html
    Dec 2007
    Toronto, Ontario, Canada
    I have this same stand for any 'heavy duty' work I do on the bike (ie: change motor mounts), but I recently bought a Venom motorcycle lift (https://www.kapscomoto.com/ca/adjust...m-7-to-10.html). It lifts the bike high enough to be able to do an oil change. Very easy to use.
    Nov 2015
    I have a Harbor Freight table lift. I bought it on sale for $299. It works very well for the Nines, but it is not heavy duty enough for my Gold Wings. It will lift them, but it is a strain on the jack and the pivot bolts.
    Apr 2017
    Ontario, Canada
    Quote Originally Posted by asillito View Post
    This is a very clever solution I was not previously aware of before buying the normal and completely NOT oil-friendly, lift.
    Makes far more sense... added a "pivot lift" to the shopping list, thanks!!
    Apr 2019
    I just ordered mine J&S lift. Can’t wait to try it out.
