No brake lights
Results 1 to 8 of 8
Thread: No brake lights
    Member Jeffro109's Avatar
    May 2016
    Las Vegas
    Default No brake lights
    I just realize this morning that I do not have any break lights triggered either from the foot or the hand. Any ideas where I should look? I was trying to find a fuse diagram that may show a brake light fuse? Any advice is appreciated.
    Dec 2016
    Saskatchewan Canada
    Have you changed anything lately to do with tail light etc? Pulled anything apart before this happened? There's a switch to trigger on both lever and foot so it sounds like the break light wire to whatever you're using.
    Sep 2013
    Cary, NC
    Post
    In the fuse box, the 15A signal controls the horn, speedometer, turn signals, tail and brake lights. If all of these are not working, then check the fuse. If only the brake light is not working , then check your switch as previously mentioned. Here's the link for the service manual.
    http://www.mediafire.com/?m2zniyn4ltj
    Jun 2017
    Florida
    Another more likely scenario could be you do have brake lights......and they are on all the time. (Which is why you don't see a difference when you press the brake lever)
    Take off your seat, uncouple the electrical connector for the rear portion of the bike, turn on your ignition switch and test voltage between the white wire with black tracer (your brake light switch leg which is 12vdc+ when one of the brake switches are closed) and the black wire with white tracer (12vdc - or negative).
    If you have 12vdc between these two conductors when NOT applying the brakes then one of your brake switches is staying closed.
    BCS
Name:	Break light.jpg
    Jun 2017
    Florida
    Here is a PDF of the service manual in case you do not have one.
    The complete wiring diagram is located just after page 12-10
    http://www.iocr.ro/tech_zone/pdf_files/VZR1800.pdf
    BCS
    Sep 2013
    Cary, NC
    Post
    Any updates on your issue?
    May 2016
    Las Vegas
    I finally got around to actually checking in. As it turns out, the brake lights work. Not. Before I just put in the wiring, I just connected to put brakes which which had been an issue before when the spring just becoming disconnected. As soon as I disconnected it, the light went off, and front brake actuator this just as it is supposed to. I backed the nuts off the switch a few turns, and everything is working perfectly. I appreciate the help. Hopefully, this helps someone else in the future as well.
    Sep 2013
    Cary, NC
    Post
    Good deal!
