Forcewinder Intake
Results 1 to 8 of 8
Thread: Forcewinder Intake
    Very Active Member RR's Avatar
    May 2017
    Australia
    Default Forcewinder Intake
    Hi fellow 109ners. Has anyone got a template for a backing plate to hide the hole around the intakes once you install them. Or a link where one might get the plates from. I don't like seeing the wires and that.
    Very Active Member wcm109's Avatar
    Feb 2014
    westport,mass
    hey! i have the thunder manufacturing tornadoe kit. if your gonna have them fabricated i could send you a template of each side. they hide everything well.
    only i wont have the oppurtunity for about 2 weeks as my bike is at painter. just an offer if your stuck.
    mods: Swampworks 310kit,Swampworks adjustable links,coastal moto mavericks,down under kit, polished rotors,chrome rear caliper,swing arm cover, drive shaft cover,cycle house extended mirror arms, basani pro street turn outs,pc III,gi pro atre,factory pro shift kit, ostrich covered seats,greggs side cover , plate bracket
    May 2017
    Australia
    Quote Originally Posted by wcm109 View Post
    That would be great if you could do that.
    Dec 2016
    Saskatchewan Canada
    You're just trying to cover the area between the cylinders?
    Feb 2014
    westport,mass
    Quote Originally Posted by RR View Post
    once i get my bike back i will pm you for your address. no problem.
    May 2017
    Australia
    That's the one mate
    Dec 2016
    Saskatchewan Canada
    This is the Thunder Tornadoes. The mounting is completely different and with your intakes the right one is much further forward. The tornadoes have a small airbox of their own so that each side sit the same. You wouldn't be able to use that configuration to fill in that area as the airbox is much wider than the opening.
    Member StuporDave's Avatar
    May 2017
    Tulare, ca
    I have the Forcewinders on my bike. Are you saying there is a cover available to cover the little black module and wire between the cylinders?
