New exhaust install
Results 1 to 2 of 2
Thread: New exhaust install
    Default New exhaust install
    Purchased a Danmoto exhaust but forgot to order a exhaust valve servo eliminator. Will the bike run okay when it is throwing a code? Should I wait until eliminator shows up before installing?
    Jun 2017
    Florida
    Quote Originally Posted by Jedinorth View Post
    I don't think that fault will put the bike into limp mode, you should be fine.
    Go burn it around the block and try out your new exhaust.
    Just get the ESE on the bike as quick as you can so your fault indicator will clear.
    With the FI light on you will not know if any other fault appears on your bike.
    https://www.meancycles.com/store/par...?partID=222600
