Fellow Toronto Member Saying HI - Page 2
Page 2 of 2 FirstFirst 12
Results 31 to 46 of 46
Thread: Fellow Toronto Member Saying HI
  1. #31
    Oct 2018
    Richmond Hill, Ontario
    Is this the website you tried: https://vrayscustomplatemounts.com/
    I'm looking at it right now.
  3. #32
    Active Member
    Apr 2019
    Quote Originally Posted by Sasnuke View Post
    Yes thanks...apparently the site linked in his post had a type-o
  4. #33
    Active Member
    Apr 2019
    Guys reminder to check your clutch cables ..19000 kms assuming it's the original... any recommendations on where to buy a replacement
  6. #34
    Oct 2018
    In my endless reading of this forum, it was mentioned that Suzuki came out with a generation 2 or version 2 (or whatever you want to call it) of the clutch cable somewhere around 2008 due to the breaking issue.
    Not sure how to differential it from the gen/version 1...but I think you would be good with a Suzuki cable.
    It was also recommended to route the cable on the outside of the front engine mount...whereas the factory routing takes it straight through the mount...literally.
    I use this online parts catalog to look up part numbers and then go hunting from there...or order them from the same place (depending on their price...which is listed in the catalog too): http://partsfinder.onlinemicrofiche....800N-K8-M109R2
    (just change the year to your bike when you get to the website)
  7. #35
    Active Member
    Apr 2019
    Ok I'll check with the local dealer tomorrow...I guess it's a good thing I checked prior to the meet....talk about hanging on by a thread
  8. #36
    Dec 2016
    Saskatchewan Canada
    Quote Originally Posted by Mani View Post
    Get a hydraulic clutch and you won't have to worry about it
  9. #37
    Active Member
    Apr 2019
    Eventually I think I will but for now I rather use that $700 for cosmetic changes 😁😎
  10. #38
    Dec 2016
    Saskatchewan Canada
    The trick is to get just the slave cylinder kit and find a C90 master setup on Ebay. I did that and saved 100s. Got the master setup complete with lever for $65
  11. #39
    Very Active Member Stavros's Avatar
    Jan 2010
    King City, Ont
    If you can’t find one in time I have a new one kicking around,let me know,you can install it,then give me the new one when it comes in...
    Stav
  12. #40
    Oct 2018
    Wow...just wow!
  13. #41
    Jan 2010
    King City, Ont
    Im sure it was the original,they were weak..by the looks of it,2nd owner didn’t have enough play at the lever..motor mounts are probably worn also..those two together along with the torque of the motor will pull the cable out of the barrel quick..they don’t sell the original cable anymore..
    Stav
  14. #42
    Active Member
    Apr 2019
    Hum now that definitely changes things...will do some more research on this
  15. #43
    Active Member
    Apr 2019
    Quote Originally Posted by Stavros View Post
    Thank you for the offer.. I'll let you know shortly
  16. #44
    Active Member
    Apr 2019
    Just grapped the cable from snow city in Scarborough ...ordered yesterday morning...recd a text this morning saying its here...time to install...thank you again for the offer
  17. #45
    Oct 2018
    Remember there's the factory routing through the front engine mount, and then the recommended on here to go outside the engine mount and along the frame.
    The choice is yours.
  18. #46
    Active Member
    Apr 2019
    My hats off to you guys that get this done on the side of the road.....thank you for the reminder ...really 20 mins to check the oil level😶
ID:	383540   Click image for larger version.
ID:	383542   Click image for larger version.
