Rear rotor removal
Results 1 to 10 of 10
Thread: Rear rotor removal
    Aug 2017
    Pennsauken NJ
    Default Rear rotor removal
    About to send rim's out to be chromed. How do I remove front and rear rotor? A detailed explanation or video would be a BIG help. Thanks.
    Dec 2016
    Saskatchewan Canada
    rotors are easy. Just get the proper sized metric allen key. I just changed mine from stock rim to new 21" rim. Just make sure it's the right size so you don't strip them and good quality hardened steel. DON'T BUY CHEAP CRAP ONES
    In the USA finding metric quality tools may be the hardest part
    Dec 2016
    Saskatchewan Canada
    Also make sure they are aware to mask off the inner hubs or they won't fit afterwards. Also the rear rim has the cush drive assembly on the inner rim and needs to be untouched with powder coating
    Feb 2009
    Oklahoma City
    I need to change my rear eventually, and Judah told me I could do it without removing the rim/tire from the bike. Lift up on jack til wheel is just barely touching the ground, take the caliper off, slide the axle bolt out a little, remove the rotor, put new one on, slide axle back home, install caliper and drop bike off lift.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Jun 2017
    Florida
    The OP said in another thread that he did remove the bolts that hold the rotor to the rim but still could not get the rotor off.
    Sometimes you have to persuade them with a little love tap or pop them off with a bit of leverage.
    BCS
    Nov 2009
    ARLINGTON, TX
    Of course you have to remove the rotor bolts first, so you’re able to remove the rotors. But yes, it can be done like that.
    Feb 2009
    Oklahoma City
    Aw gee ma, do I really? Thought I could remove the rotors with the bolts still in place!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Nov 2009
    ARLINGTON, TX
    I know you knew that Rob. It was intended for “some others” who might have taken your previous the post out of context, or misinterpreted it.
    Jun 2017
    Florida
    Without making mountains......the OP had posted in another tread that he already removed all 6 bolts but still could not get the rotor off.
    I am not the smartest of men.....but i assumed that he already had the rim off the bike and he is simply wanting to know why the Rotor will still not separate from the rim.
    I am sure it is possible I am "misinterpreting" this.....but I don't believe I am.
    https://www.m109riders.com/forums/sh...d.php?t=346292
    BCS
    Nov 2009
    ARLINGTON, TX
    BCS
    Charles, come on man. My previous post here had nothing at all to do with YOU misinterpreting anything. I hadn’t even considered you when I posted that response. In fact, my intent was to prevent anyone at all from taking Rob’s comments vaguely, as the method I informed him about is one I know of that can be used if/when someone doesn’t want to remove the entire wheel and tire from the Swing Arm area. I was reponding to Rob regarding something him and I had conversed about months ago, via text...and you took my comments to “him” as a personal attack toward you? I don’t get it Bro. I was 100% clear that the OP had already removed his wheel, but was having trouble removing the rotor. I had previously read his other post as well. I wasn’t even commenting about the OP’s situation at the point I responded to Rob.
    Have a good one Bro.
