Revo headlight
Page 1 of 2 12 LastLast
Results 1 to 30 of 60
Thread: Revo headlight
    Jan 2009
    Hampton, Ga
    Default Revo headlight
    Look what just showed up on my front porch this morning!!!
    -Josh
    Apr 2017
    Ontario, Canada
    It followed you home!! Means you can keep it!!
    Very cool. Looking forward to the results!
    Jan 2009
    Hampton, Ga
    Here's the old light with the new light, the new light mounted and the ridiculous output after installation.
    -Josh
ID:	382712   Click image for larger version.
ID:	382714   Click image for larger version.
    Jan 2009
    Hampton, Ga
    And Here's the difference In the low and high beam patterns. The first two are low and high with an led bulb in the stock housing.
    -Josh
ID:	382720   Click image for larger version.
ID:	382722   Click image for larger version.
ID:	382724   Click image for larger version.
    Apr 2008
    mass
    Light looks great
    Apr 2017
    Ontario, Canada
    Pics look great! Looks like high beam has an awesome throw and low has a decent cutoff. Nice!
    Very Active Member VzrDean1800's Avatar
    Sep 2015
    Elora, ON Canada
    Quote Originally Posted by gottattooz View Post
    -Josh
    Hi Josh,
    Two pics show a full flood of light, and two show a sudden cutting off of light. Which pics are the new light? I know you said which is what, but I've been getting this annoying pop up when I'm on this site lately, and it makes things fit differently on my Android tablet.
    Thanks,
    Dean
    Nov 2015
    Josh,
    Is the size of the back of new headlight the same as the OEM headlight. I am concerned about lack of space in the cowl because of the air horn.
    Jan 2009
    Hampton, Ga
    Quote Originally Posted by VzrDean1800 View Post
    Hi Josh,
    Thanks,
    Dean
    The new light has the cut off for low beam, and full flood for high beam.
    -Josh
    Jan 2009
    Hampton, Ga
    Quote Originally Posted by Metalman View Post
    Josh,
    They are the same dimensions. Swap over the rubber grommets and bolt it right in.
    -Josh
    Very Active Member Richard's Avatar
    Jul 2007
    Spring Hill, FL
    Josh, Is a cooling fan needed with this light?
    Jan 2009
    Hampton, Ga
    Quote Originally Posted by Richard View Post
    No, Richard. It's all one piece.
    -Josh
    Dec 2016
    Saskatchewan Canada
    Did you damage anything when you laid on it's side?
    Dec 2016
    Saskatchewan Canada
    The middle two are the Revo correct?
  17. #15
    Jan 2009
    Hampton, Ga
    Correct. I don't know why it loaded them that way. The picture with the distinct cut off and the cut off with the spot light are the new Revo headlight pattern.
    -Josh
  18. #16
    Nov 2015
    Josh,
    Can you post a link to that new LED headlight?
    Mike
  19. #17
    Feb 2009
    Oklahoma City
    Pic taken while leaning over in a hard corner, I suppose. LOL!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  20. #18
    Apr 2017
    Ontario, Canada
    Josh,
    Mike
    Just helpin' a couple brothers out...
    REVO: https://www.revo-cycles.com/shop/m10...1800r-vzr1800/
    HOGLIGHTS: https://hoglights.com.au/products/su...oulevard-m109r
    ALIEXPRESS: https://www.aliexpress.com/item/Blac...956068534.html
    ALIEXPRESS: https://www.aliexpress.com/item/Black-Headlight-wirh-halo-for-SUZUKI-M109R/32961495554.html
    They sure *look* all the same... no idea if they *are* all the same.
  21. #19
    Jan 2009
    Hampton, Ga
    Thanks. I went with Revo. The Hoglights website went over $500 after shipping. I don't know if that's Australian dollars or what.
    -Josh
  22. #20
    Nov 2015
    They are all expensive. Josh, can you give us a report after riding in the rain at night?
  23. #21
    May 2018
    New Jersey
    I have the hoglights version. They're all the same. Mine came out to about 375 shipped on sale a few month ago. Still haven't had it out at night though.
ID:	382828   Click image for larger version.
  24. #22
    Jan 2009
    Hampton, Ga
    I just rode around the block and the light was aimed too low. The high beam definitely made up the difference. There is no adjustment, like the stock light, so I put a thicker bushing at the bottom alignment peg. These are the pictures from that adjustment. I need to cut the bushing in half, but i have to remove the fairing and headlight every time I make an adjustment. But you get the idea about how bright the light is.
    -Josh
ID:	382832   Click image for larger version.
ID:	382834   Click image for larger version.
  25. #23
    May 2018
    New Jersey
    -Josh
    Good idea for a fix. I also run driving lights in my blinkers which help.
    Curious to see how mine will throw light.
  26. #24
    Jan 2009
    Hampton, Ga
    I rode to work today so I could give the headlight a real worldtest besides just going around the block. I can see everything. Anything reflective lights up farther than you can see. The high beam was aimed up into the trees, so it wasn't helpful at all. When I got home, I cut that bushing in half and now it's perfect.
    I know the price tag is high for this unit, but being able to see better at night makes me feel so much safer. I saw 4 deer on the side of the road, I mean 30-40 feet off the road clear as day. Hopefully I'll make it to the MAM this year and I'll show as many riders as I can the difference.
    -Josh
ID:	382990   Click image for larger version.
  27. #25
    Jan 2009
    Hampton, Ga
    Well, since you asked......
    I rode home in the rain tonight. I had an opportunity to go home on my lunch break and swap the bike for the wagon, but I wanted to see how the light performed in the rain at night.
    It wasn't raining quite as hard as it was a few weeks ago, but I can tell you visibility was a whole lot better with the Revo headlight.
    -Josh
  28. #26
    Dec 2016
    Saskatchewan Canada
    That does look great. No diffraction of the light
  29. #27
    MoCo Maryland
    Josh,how long did it take to arrive
  30. #28
    Jan 2009
    Hampton, Ga
    It wasn't very long. I believe the website said 18 days and it got here in 10-12.
    -Josh
  31. #29
    Active Member
    Jun 2016
    NorthCoast
    Took my payment on the 12th.
    Updated my status to "shipped" on the 16th.
    It was in my hands on the 20th.
    -- 8 days
  32. #30
    Very Active Member Joker's Avatar
    Jan 2007
    Default Hey Josh...
    -Josh
    Can you run the headlight with just the halo on and not the highbeam and lowbeam ?
