USB Outlet mount advice/questions
Results 1 to 19 of 19
Thread: USB Outlet mount advice/questions
    Active Member Mythos's Avatar
    Nov 2018
    East Orlando, FL
    Default USB Outlet mount advice/questions
    OK M109R family, I've purchased the below USB outlet with a desire to mount it to my bike. Ideally I'd like to mount it to the front of the Speedometer housing just behind the risers. What I'm looking for may not exist so I'm wondering if there's someone who can fabricate it, or recommend something similar that will accomplish what I'm looking to do. The outlet itself is a fairly standard cylindrical threaded metal device with a screw on ring, ideal for mounting through a flat surface with the ring tightened from underneath to hold everything in place. What I'm looking for would be something along the way of a (chrome) bracket that would attach via a couple of bolts with a backing plate (some drilling will be required here) to the front of the Speedo cover which would have effectively a half egg shaped receiver that the USB outlet could sit or thread into with a rubber boot at the end for the wires coming out (similar to the Kuryakyn handlebar deal's shell...). Anyone know of a premade device like this, or have the ability to fabricate such a mounting bracket?
ID:	382326Click image for larger version.
Name:	USB OUtlet Mounting bracket design.jpg
ID:	382328 Click image for larger version.
    Michael -
    2012 M109r LE - East Orlando, FL
    Jun 2018
    Going by your drawing, it'll depend on the length of it all. Depending on the size of the unit you bought, it'll probably be easier to delete the "egg" and use the threaded back to secure behind the headlight nacelle somewhere. It all depends on the dimensions of the USB which I don't see here.
    Very Active Member AU109's Avatar
    Sep 2007
    Whyalla, South Australia
    Quote Originally Posted by BOSS_man View Post
    This is what Id be doing (and I am doing) put it through the black backing of the nacelle.
    Sent from my iPhone using Tapatalk Pro
    Cheers Mike
    ___________________
    K7 M109R LE Blue
    260 and a few other bits!
    Apr 2014
    Chesterfield, VA
    I installed mine on the back of the headlight bucket.
    Nov 2018
    East Orlando, FL
    I may end up going this route, but I kinda of wanted it a bit more easily accessible which is why I had thought it would be good behind the Speedo. I saw a video where a guy in Australia or New Zealand did it, but there wasn't a lot of info on what he used to mount it this way. Check out the ~ 20 second mark:
    https://youtu.be/bBJnR02s6e0
    Michael -
    Jun 2017
    Florida
    Another advantage to putting your charger port on the handlebars or on the back of the headlight bucket is that your phone or whatever device you are plugging into this port is usually mounted to the handlebars.
    If you put the charger port on the tank it is stationary when you turn the handlebars.....so you will have variable length in your cable from the port to your device as you move the bars
    If the port is located in a place that also travels with the handlebars then the cable length between the port and the device is static and does not change as you move the bars.
    BCS
    Sep 2007
    That video he has used a USB with the feet attached.
    Not much good for the unit you wish to use (I have the same unit).
    As above, in the bucket isnt hard to access at all.
    Cheers Mike
    ___________________
    K7 M109R LE Blue
    Nov 2018
    East Orlando, FL
    Looks like it'll be the bucket...
    Michael -
    Apr 2014
    Chesterfield, VA
    Quote Originally Posted by Mythos View Post
    Check out techflex if you want to hide the charging cables. It comes in black or chrome and will make the cable blend right in with whichever color brake lines you have. I used techflex in several locations on my bikes. You can see pictures in my build thread. There is a link to that thread in my signature below.
    Here is a link to techflex website. I bought mine from Wirecare.com. That was a few years back, so shop around. You may find better pricing somewhere else.
    https://www.techflex.com
    Member StuporDave's Avatar
    May 2017
    Tulare, ca
    I mounted my USB on the front edge of the Speedo housing. The switch above it energizes the auxiliary fuse block I added to the bike for accessories. It glows when on. The power comes on with the key, or when I push the switch. I use it to recharge my headphones mostly. My phone mount also has a USB outlet on it connected to the same circuit.
Name:	USB mount.jpg
ID:	382334Click image for larger version.
Name:	Phone mount.jpg
ID:	382338Click image for larger version.
Name:	Under shot of phjone mount.jpg
    Oct 2018
    Richmond Hill, Ontario
    Quote Originally Posted by StuporDave View Post
Name:	USB mount.jpg
    Nice setup with the USB. I think I have the USB charger, but couldn't think of a good spot to mount it.
    Very Active Member 06MrMike's Avatar
    Jun 2006
    Westmore, VT
    I purchased the Revo usb hub that replaces the triple tree nut, does anyone know what the torque spec is for that nut?
    http://www.revo-cycles.com/shop/revo...r-port-socket/
    Mike
    Jun 2017
    Florida
    The steering stem head nut is 65 FT# (C on the drawing below)
    BCS
    Oct 2018
    Quote Originally Posted by 06MrMike View Post
    Mike
    65 ft lbs
  17. #15
    Jun 2017
    Florida
    Here is a link to the Service Manual in PDF format that you can download.
    http://www.iocr.ro/tech_zone/pdf_files/VZR1800.pdf
    BCS
  18. #16
    Jun 2006
    Westmore, VT
    BCS
    thank you!
  19. #17
    Apr 2008
    mass
    I mounted mine to the back of the narcelle used 3m tape been there for yrs
  20. #18
    Active Member
    Jan 2019
    Barrie,ON
    I probably can make it.
    Sent from my SM-N960W using Tapatalk
  21. #19
    Very Active Member fatboy99's Avatar
    Jul 2012
    Smashville, TN
    BCS
    Big o thanks on that book man!
