C109 turn flasher?
Results 1 to 5 of 5
Thread: C109 turn flasher?
    Member Fast Daddy's Avatar
    Apr 2014
    Southern,Md
    Default C109 turn flasher?
    I have replaced all my turn signals with LEDs. Now, to cure the rapid flash I want to replace the flasher with an electronic unit for LED lights, but don't see a flasher in the electric schematic. I'm not a fan of resisters and their heat. Did Suzuki combine a flasher with another function relay?
    Jun 2018
    what year is it? I have a '14 M109 and the flasher is located on the left front of the battery. I know yours is a C but you can start there. Here is a link with pics.
    https://www.m109riders.com/forums/sh...d.php?t=161024
    Here's where to buy: https://www.revo-cycles.com/shop/rev...ignal-flasher/
    Aug 2017
    uk
    7 pin, combined with the kick stand relay iirc (m109)
    Apr 2014
    Southern,Md
    Thanks for the information. I can see the relay behind the engine, wedged in front of the battery box. I'm out of day light for now.
    Apr 2014
    Southern,Md
    I bought the plug and play flasher from Revco. Took me about an hour to gain access to the flasher, bus the replacement works great, Now my battery stopped charging. There is no output to charge the battery, so to the dealer for the long over due rectifier recall.
