Poor engine performance at medium engine speeds
Results 1 to 16 of 16
Thread: Poor engine performance at medium engine speeds
    Default Poor engine performance at medium engine speeds
    Hello everyone! I am writing through a translator, so errors are possible.
    problem at the last engine rpm. on fast turns and idling all is well.
    replaced the candles, all the filters - nothing has changed.
    Very Active Member 4fun's Avatar
    Apr 2018
    Spring Hill Florida
    bad gas? clogged injectors or if its carburetor clogged jets.
    Freedom Performance Exhaust, Exhaust Servo elimator,O2 sensors Removed,PC V,Grasshopper seat rest,Rear seat backrest,USB Phone charger,Pair valve blocked off, LED light kit with remote, derby cover M109R,JDM switchbacks. JDM H4 headlight,M109R swing arm cover,M109r brake cover,Tank bra, Spike air intake, Quick disconnect rear seat back,quick disconnect cowl, Powder coating all over, Factory Pro Evo shift star
    Jan 2009
    Nitra, Slovakia
    Quote Originally Posted by Solovev View Post
    Did you change all 4 "candles"= spark plugs?
    Is your FI indicator light ON, by any chance??
    Yes, I changed 4 spark plug.
    changed the gasoline filter and air filters.
    the injector is clean, the nozzles are perfect.
    FI - does not burn.
    Apr 2018
    Spring Hill Florida
    compression and plug wires aka coils
    Dec 2016
    Saskatchewan Canada
    What plugs did you use? Some have had bad luck with Iridium plugs doing what you are describing
    CR7EK - ngk,
    before replacing the spark plug was the same
    Anyone help me?
    Mar 2013
    Calgary, AB
    I would start by testing the coils and the spark plug leads (wires) first. If everything checks out there, and while you have the tank off, you should inspect all the wire connectors to make sure all the pins are in place and none of the connectors have pulled out of the housings that retain them. This is a problem with the "M" when removing the gas tank, there is a connector where it is common for the wire to pull out of the housing, but still look like it's attached. Just some ideas for you to check out. Good luck.
    Very Active Member TheFNG's Avatar
    Sep 2014
    Cape Cod MA
    I also have that spudder at mid range. While ridding at moderate speed say 3rd gear and the engine has balanced with RPMs to throttle position ill start to feel and hear it a little. I am also curious if there is a real problem or if its just an inherent quirk of our bikes with the high compression ratio. I have no loss of power when I want it and it sounds great as long as the engine is under load. Its only when the RPMs are balanced with throttle position. Don't know how else to express that. I know my engine is running well. Just today I was ridding with a buddy. He has a Indian Chieftain. He had the performance Cams installed and brags about how much more power his bike has now and how he cant keep the rear wheel from spinning thru all his gears. Yeah well.....He couldn't pull away from me today. We never had a real chance to run out, but 1st-3rd from a slow start I was faster. LOL.
    09' C109RT Thunder Teardrop Intakes;Cobra PowrPro;GIpro TRE/gear indicator;cobra exhaust;Tsukayu 7" Stereo/GPS Boox One Fairing;Tsukayu Jumbo Strong bags;fender chrome; Rear Master cylinder Chrome;Tank bib;headlight visor,driving light visors,speedo visor and directional visors;Throttle lock; Kuryakyn cup holder;Kuryakyn mirrors;Kuryakyn Dually ISO Highway pegs;TMS Trunk; zXe head light and driving light bulbs;Draggers;Denali air horn
    Quote Originally Posted by TheFNG View Post
    Most riders believe that this is a breakdown of high-voltage wires. I will experience everything in the spring. we have winter so far, very cold.
    I hope this topic will be relevant and we will find a problem.
    What is your exhaust system? Is power commander or fi2000 installed? exhaust is drilled on my motorcycle, but the injection control system is not installed, can this be the case?
    Very Active Member "Hunter"'s Avatar
    Sep 2011
    Belgium
    go to Dealer Mode see page 72 https://drive.google.com/file/d/0Bw2...lXQTNRcU0/view
    or http://ge.tt/1dsjrLv2
    Self-Diagnostic Procedures
    Page 81
    DTC Table
    Page 89 ......
    TP Sensor Adjustment page 203
    "Hunter"
    Suzuki M1800R - no rules great fun
  17. #15
    Quote Originally Posted by Hunter";3977800]go to Dealer Mode see page 72 [URL]https://drive.google.com/file/d/0Bw2H4asOoJ3vZEVmOXlXQTNRcU0/view[/URL]
    or [URL="http://ge.tt/7HbjoLv2
    http://ge.tt/1dsjrLv2[/URL]
    Page 81
    DTC Table
    Page 89 ......
    Correct position...
  18. #16
    corrected. cause of injector synchronization interruptions
ID:	384642   Click image for larger version.
ID:	384644   Click image for larger version.
