Model Help... variance and differences
Page 1 of 2 12 LastLast
Results 1 to 30 of 50
Thread: Model Help... variance and differences
    Aug 2018
    ACT, Australia
    Default Model Help... variance and differences
    Seems to be my luck with bikes. My last one was an inbetween model also.
    I have purchased a 2nd hand M109. Went to Suzuki Australia with the VIN number to confirm year model and model number.
    They tell me it is a 2010, VZR1800Z L0
    Cool thinks I. Easy.
    Nope. Go to Suzuki Parts Monster - No 2010 VZR1800, no M109 listed.
    Has the gear indicator like the 2011s. Can't find the L0 listed in the models on the parts fiche.
    Can anyone help with background or insider knowledge?
    Seems to me the 2010 is actually a transition model between the 2009 and the 2011. The Yr of MFG is 2010 and early 2010 but wondering if it isn't a 2011 transition.
    Thanks in advance.
    Feb 2009
    Oklahoma City
    The only thing I'm aware of is that the 2010 was available everywhere but the U.S. Know of nothing else. Maybe it wasn't available in Australia as well for that year?
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Very Active Member TM109R's Avatar
    Mar 2007
    Glen Ellyn, IL
    Obviously it was a available in AU, the zero at the end of the model number is the indicator for the model year.
    Sent from my SM-N960U using Tapatalk
    Brakeaway Throttle Lock / Rivco Passenger Boards / K&N Air
    Apr 2017
    Ontario, Canada
    Depending on what part(s) you're looking for, it may not matter much.
    My understanding is:
    2006-present = All mechanical parts are the same except for an updated clutch pack in 2011 I believe.
    The only other change beyond paint and stickers since 2006 is the minor cosmetic refresh in 2011.
    Others will no doubt confirm or clarify this further, very shortly.
    Aug 2018
    ACT, Australia
    My big thing is I'm looking at a TRE, primarily the HealTech x-TRE to keep the gear indicator. It's hard to confirm which model I actually have. Luckily the guys at HealTech have sent me the instructions and my mechanic mate is going to check to see if it will fit mine or if the config is 2009 type.
    Very Active Member blacklightning's Avatar
    Oct 2007
    Apex, North Carolina
    You can double check this, but I think the 2010 is the exact same as the 2011 that was sold in the US. Even the LE edition for 2010 had the same color scheme as the 2011 LE. I am 99% sure that this is correct. Welcome to the group.
    Feb 2009
    Oklahoma City
    Mostly. The 2006 model year only, the engine side covers are plastic. They changed them to metal in 07. This includes the covers at the top of the cylinders for the plugs,meatl where mine are plastic. 07 up weigh 7 pounds more than the 06.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Apr 2017
    Ontario, Canada
    Right right and now that reminds me of another post mentioning the rear grab rails had similar changes - from metal to tin+rubber.
    As for the TRE - I don't have one but many do and we will surely hear from them shortly.
    Jun 2017
    Florida
    If your bike came from Suzuki with the tac located in the head light bucket and with a gear indicator then you would use the same X-TRE as the 2011.
    http://www.meancycles.com/store/part...?partID=225512
    It seems most of these parts are coming from the USA and we did not get the 2010 model here, which is why they list the part starting at 2011 model year.
    BCS
    Feb 2009
    Oklahoma City
    BCS
    Right, but the OP is Down Under.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Dec 2016
    Saskatchewan Canada
    My 2012 has plastic covers
    Feb 2009
    Oklahoma City
    The big chrome engine side covers and the sparken plug covers? Really? Likely a previous owner changed them out? I never heard that Suzuki went back to plastic. Know for a fact they changed to metal in 07, cause I waited til the 07's came out before buying my 06. Wanted to compare the white 07 to the silver 06. Liked the silver better.
    Also Jerzee Devil told me what was required to swap out the plastic spark plug covers for the metal ones. You have to buy the mounting brackets as well, they're different than the plastic mounting brackets.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    Jun 2017
    Edmonton, AB
    The lower covers on my 2016 are metal but the covers at the top of the cylinder heads are black glossy plastic.
    Jun 2017
    Florida
    Here is a picture of the plastic and metal covers side by side.
  17. #15
    Jun 2017
    Florida
    Plastic ones cost $55 - $60 each new.
    Metal ones cost $197 each new.
    I have a set of metal ones squirreled away and will take $50 each for them or $175 for the set of 4 (Buyer pays shipping) if anyone is looking for a metal set.
    BCS
  18. #16
    Feb 2009
    Oklahoma City
    BCS
    You have the mounting brackets that go with them?
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  19. #17
    Jun 2017
    Florida
    Yes I do.
  20. #18
    Feb 2009
    Oklahoma City
    Yes I do.
    Then I'll take all four of them for that price. Do you know what shipping is to 73110 (Oklahoma City)?
    I'm at work til midnight, can't do paypal here, no smart phone. PM me your pp address and I'll take care of it when I get home tonight!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  21. #19
    Jun 2017
    Florida
    It will take the large flat rate box to ship all 4 of them which will be $19 to ship.
    I will PM you my paypal.
    Wrapping them up and boxing them now, send me your address and I will get them sent off in the AM.
    BCS
  22. #20
    Feb 2009
    Oklahoma City
    I don't like unround numbers, I'll just make it $200.00 even. No biggie. The $19 was going to make it $194 anyways. Pay for your gas for the trip!
    One of my plastic ones, the chrome finish is ripply. Heat must have caused the "chrome" to become unbonded, or something. Been wanting to do the metal ones for like two years.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  23. #21
    Jun 2017
    Florida
    If you find a need to replace the 4th plastic one to sell the set, I have 1 plastic cover also. (its the larger of the 2 sizes)
    BCS
  24. #22
    Feb 2009
    Oklahoma City
    I don't figure on selling them. May strip them of the fake chrome finish and experiment with some different color variations. Or just deep six them!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  25. #23
    Feb 2009
    Oklahoma City
    BCS
    Did you get the dough? Paypal says you did.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  26. #24
    Dec 2016
    Saskatchewan Canada
    Just the spark plug covers are plastic
    They just push onto rubber mounts
  27. #25
    Dec 2016
    Saskatchewan Canada
    I notices one of mine is rippled also
  28. #26
    Jun 2017
    Florida
    Yep all good thanks, your package is on the way, I PMed you the tracking number.
    BCS
  29. #27
    Jun 2017
    Florida
    If it is the larger of the 2 sizes and your brackets line up with the plastic one I posted earlier let me know.....I have one plastic plug cover and I have no need for it.
    I will take a picture tonight and post it.
    BCS
  30. #28
    Feb 2009
    Oklahoma City
    BCS
    Okay, thanks man.
    As to the plastic upper pieces, I thought all four were identical. I recall when I took mine off to do the sparken plugs, I got them mixed up on the garage floor, but had no issues putting them on anyways. Or are you saying the metal ones are a little larger than the plastic ones, or vice versa?
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  31. #29
    Dec 2016
    Saskatchewan Canada
    Okay, thanks man.
    pretty sure I did the same thing when I changed plugs and they all fit back on. But maybe that's why they bubble is if they are stretched on the wrong cylinder
  32. #30
    Jun 2017
    Florida
    The metal ones are 2 different sizes, you put a large and small on each side of the bike.
    One is just a bit larger (wider) than the other.
    BCS
