Model Help... variance and differences - Page 2
Page 2 of 2 FirstFirst 12
Results 31 to 50 of 50
Thread: Model Help... variance and differences
  1. #31
    Dec 2016
    Saskatchewan Canada
    The metal ones are 2 different sizes, you put a large and small on each side of the bike.
    One is just a bit larger (wider) than the other.
    BCS
    Well, will have to check. Only had them off once in the spring
  3. #32
    Feb 2009
    Oklahoma City
    Yup. Had mine 12 years and those covers were off one time. Soon to be off again once these new metal ones show up.
    As for the metal ones being two different sizes, how does one know where to put the larger ones versus the smaller ones? The mounting brackets will be identical. Interesting conundrum!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  4. #33
    Jun 2017
    Florida
    I will get some pics of my bike for you tomorrow.
    BCS
  6. #34
    Jun 2017
    Florida
    My bike comes apart about once a month when I am home to clean and polish everything.
    BCS
  7. #35
    Feb 2009
    Oklahoma City
    BCS
    And I thought I was anal! Only reason I ever noticed one of my four sparky covers was rippled was because I took them off to change the spark plugs for the first time ever, after owning it 11 years. LOL!
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  8. #36
    Aug 2018
    ACT, Australia
    Default Thanks mate
    Quote Originally Posted by blacklightning View Post
    You can double check this, but I think the 2010 is the exact same as the 2011 that was sold in the US. Even the LE edition for 2010 had the same color scheme as the 2011 LE. I am 99% sure that this is correct. Welcome to the group.
    This was what I was starting to suspect with the things I'd heard here and the other rumblings around the traps.
    Wondering if Suzuki didn't use Australia as an pre-release/experiment before RoW.
    The above makes a fair bit of sense from what I've seen.
  9. #37
    Aug 2018
    ACT, Australia
    If your bike came from Suzuki with the tac located in the head light bucket and with a gear indicator then you would use the same X-TRE as the 2011.
    http://www.meancycles.com/store/part...?partID=225512
    It seems most of these parts are coming from the USA and we did not get the 2010 model here, which is why they list the part starting at 2011 model year.
    BCS
    If the comment 1 or 2 above yours fits is true then this would fit.
    I'm tempted to contact Suzuki home rather than Australia and ask them. I can confirm the taco With gear indicator are in the headlight bucket, and it just forward of the risers.
    I'll probably be getting my mech to look at it in a week or so.
    Thanks for the feedback.
  10. #38
    Aug 2018
    ACT, Australia
    Default Deals on deals
    Glad you and Bering_C_Sparky were able to sort a deal out.
  11. #39
    Jan 2009
    Fergus, Ontario, Canada
    Quote Originally Posted by Lokir View Post
    2010 model was also sold in Canada. That one had tach moved to the
    headlight bucket, had improved clutch, and had 5 spoke wheels.
    So If your bike looks like that, then you need X-TRE and Ausie Suzuki was correct.
    As said before, USA did not have 2010 model sold at all.
  12. #40
    Apr 2017
    Ontario, Canada
    Interesting.
    I always knew the 2011 was the "new" version and the 2010 was not sold in the USA, but didn't know the 2010 was some sort of freaky hybrid also? So the 2011 "international" changes actually started with the 2010 "not-USA" version?
  13. #41
    Jan 2009
    Interesting.
    I know nothing about any hybrids. "New and slightly improved" models started in 2010 and are that way until now.
    Because 2010 were not sold un the USA, the aftermarket listings are confused and mostly do not list the parts for 2010,
    and are also saying that "new improved" M109r model was starting in 2011.
  14. #42
    Apr 2017
    Ontario, Canada
    Because 2010 were not sold in the USA, the aftermarket listings are confused and mostly do not list the parts for 2010,
    Sorry, I used the word "Hybrid" casually, meaning a, "Frankenstein / Transition / In-Between" model, thinking it was some sort of random mix of parts "not quite 2009, not quite 2011". But as you clarified, it seems the only thing unique about the 2010's is that the USA didn't get any. So the common practice of referring to 2011 as the model change year isn't really true (?) - it is actually 2010 (which, in "Americanese," translates to 2011).
    Good to know, thevili - always a refreshing source of info!
    Thanks!
  15. #43
    Feb 2009
    Oklahoma City
    BCS, question on those metal cylinder covers. I think from looking at them, the two short abbreviated ones go on the left rear and right front, where the spark plug COPS are located and the hose goes up from the airboxes. Because they have a spot of black foam in them, likely to prevent shorts on the COPS. But why do the plastic covers fit without being chopped up like these metal ones? And does the abbreviated stump show when on the bike? May not be able to do anything with them for awhile, have a huge winter storm coming are way this weekend.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  16. #44
    Jun 2017
    Florida
    I forgot to get pictures for you and now I am in at work in Seattle.
    I can have the wife take some pics of my bike though and I will get back to you.
    BCS
  17. #45
    Member SVto109R's Avatar
    Apr 2017
    Columbus, OH
    Quote Originally Posted by TM109R View Post
    Obviously it was a available in AU, the zero at the end of the model number is the indicator for the model year.
    Sent from my SM-N960U using Tapatalk
    My '16 VIN ends in 7...
    I know 16 and 17 are identical but...
    23" BOSS Mimic Front Wheel - 6 Degree Triple Tree - Longshot Fender - Knight Rider LED Light - 24 LED Strips - 6000k Projector HID Headlights Conversion - 1000W 4 Channel Speaker Setup - Matte Engine Guards - Longhorn Offset Highway Pegs - Color matching Powder Coated Derby Cover - Blacked Out Turn Signals - USB Charging Port - Stainless Steel Brake Lines - White LED Gauge Conversion - Velocity Pro 2into1 Exhaust... [more to come]
  18. #46
    Jun 2017
    Florida
    My 07 VIN # ended in 1
    BCS
  19. #47
    Apr 2017
    Ontario, Canada
    10th digit of VIN is model year.
    My 2016 shows "G" which is 2016.
    6=2006
    9=2009
    A=2010... etc
    https://www.cyclepedia.com/motorcycle-vin-decoder/
  20. #48
    Jun 2017
    Florida
    Had my wife look and send me some pictures.
    Hard to tell exactly but it does look as if the snubbed ones go on the left rear and right front.....At least that't how it looks like they are on my 08 and also the pics I have of my 07.
    Also makes since that they would go that way due to the placement of the rubber boots for the intakes.
    BCS
  21. #49
    Jun 2017
    Florida
    Here are a couple of photos she sent.
    BCS
ID:	381226   Click image for larger version.
  22. #50
    Aug 2018
    ACT, Australia
    Default Soon to know
    So I got details for fitting the X-TRE from HelaTech and looked for the connector.
    Found it so have ordered one and will update this if it fits and works.
