WTB - Accident Parts
Results 1 to 12 of 12
Thread: WTB - Accident Parts
    Active Member Darkwing_Duck's Avatar
    Dec 2008
    Hood River, OR
    Default WTB - Accident Parts
    Laid my baby down beginning of August. My broken clavicle, 4 ribs, and shoulder blade are finally in shape to begin repairs. Bike went down on the left side, hard. I'll reply with a full list later today. ;(
ID:	380336   Click image for larger version.
ID:	380338   Click image for larger version.
ID:	380340   Click image for larger version.
    2007 M109R in Red
    Undertank Intake, TrackDay TRE, Debadged, Driver Boogie Boards, 2" Kewl Metal Riser Extensions, Custom Bungee Buttons, Grasshopper Driver backrest, Dunlop E3 250
    Dec 2008
    Hood River, OR
    Part Number Description Notes
    53111-48G00-YHL FENDER, FRONT (RED) MODEL K7 Front fender
    35100-48G31-999 HEADLAMP ASSY Headlight
    51821-48G00-YHL COVER, CENTER (RED) MODEL K7 Headlight Cowling
    51811-48G00 COVER, HEADLAMP Headlight Cowling - Chrome
    34257-48G00 LOWER COVER Tachometer housing, front
    34256-48G00 UPPER COVER ASSY Tachometer housing, rear
    56600-14G20 MIRROR ASSY, REAR VIEW LH MODEL K7/K8 Left Mirror
    56500-14G20 MIRROR ASSY, REAR VIEW RH MODEL K7/K8 Right Mirror
    57621-48G00 .LEVER, CLUTCH MODEL K6/K7/K8 Clutch Lever
    44100-48G00-YHL TANK ASSY, FUEL (RED) MODEL K7 E3,E28 Gas Tank
    63110-48G00-YHL FENDER, REAR (RED) MODEL K7 Rear Fender
    41621-48G00 GRIP, FRAME HANDLE LH Rear Left Frame, Chrome
    43621-44G00 .BAR, LH Left Rear Foor Peg
    25600-48G10 LEVER ASSY, GEAR SHIFT Shifter
    43521-48G01 BRACKET, FRONT FOOTREST LH Shifter bracket
    01580-1085A BOLT, LH Shifter bracket bolts
    2007 M109R in Red
    Apr 2017
    Ontario, Canada
    Very sorry to hear. Glad you are healed up enough to get back into it.
    Dec 2008
    Hood River, OR
    Thank you. Yeah, found out healing ribs suck!
    2007 M109R in Red
    Very Active Member VzrDean1800's Avatar
    Sep 2015
    Elora, ON Canada
    Take a good close look at your left side chrome clutch cover. Often after going down on that side, the foot peg mount punches a slight ding into that cover. That"ding" starts to leak oil, then more oil, etc. The oil would only leak from mine while riding. Had a hell of a time figuring out where all the oil on the left side of my bike was coming from. Turned out it was from the ding. That cover isn't cheap!
    Cheers,
    Dean
    Dec 2008
    Hood River, OR
    Clutch cover is fine. Fixing the driver side peg and holder, so it can shift. Will be "drivable" then. Here are some pics. Welcoming offers if anyone wants to buy it whole and as is
    2007 M109R in Red
    Dec 2008
    Hood River, OR
    First 5 pictures.
ID:	384004   Click image for larger version.
ID:	384006   Click image for larger version.
ID:	384008   Click image for larger version.
ID:	384010   Click image for larger version.
    2007 M109R in Red
    Dec 2008
    Hood River, OR
    Second 5 pictures.
ID:	384014   Click image for larger version.
ID:	384016   Click image for larger version.
ID:	384018   Click image for larger version.
ID:	384020   Click image for larger version.
    2007 M109R in Red
    Dec 2008
    Hood River, OR
    Third 5 pictures.
ID:	384024   Click image for larger version.
ID:	384026   Click image for larger version.
ID:	384028   Click image for larger version.
ID:	384030   Click image for larger version.
    2007 M109R in Red
    Dec 2008
    Hood River, OR
    Last pictures.
ID:	384034   Click image for larger version.
ID:	384036   Click image for larger version.
    2007 M109R in Red
    Dec 2008
    Hood River, OR
    MAINTENANCE
    All receipts since new.
    New tires two years ago.
    New battery last year.
    Oil, filter, rear end oil, changed every year.
    CHANGES
    GI Pro w/ATRE
    Modified intakes, see my other parts for details.
    NO holes ever drilled. Always used factory parts and mounts.
    Laid down, left side, August 2nd.
    2007 M109R in Red
    Very Active Member Weedahoe's Avatar
    Aug 2014
    Albany GA
    I have a front fender, headlight cover and tach cover
