LED Lighting Project
Results 1 to 17 of 17
Thread: LED Lighting Project
    Active Member
    Jul 2018
    Default LED Lighting Project
    Hi guys, in the middle of an LED lighting project. I put clear lenses on all four turn signals (I bought from two different vendors on Amazon; none was an exact fit, although I was able to make alterations to each set to make it work), and put 6000k LED's on the front turn signals (I initially ran 6000k LED's on all four corners, but the rear blinkers weren't blinking at all, so I'm just running them on the front).
    I do have a bit of the "hyper blink", since I'm not running a separate resistor to knock down the volts, but actually, kinda like the rapid blinkers; it calls more attention to myself, which is exactly what I want (especially as dusk is coming sooner every week in the mid-Atlantic / DMV area).
    Will see if I end up getting pulled over and getting an equipment change ticket, but running it as is for now.
    Lastly, I need to update the headlight; this halogen is terrible. Looking for a H4 LED headlight that has 6000k/65000k warmth that will fit the housing and still trying to decide on a bulb.
    Anyone on here do a H4 headlight bulb replacement and have a bulb brand you like or can recommend? Especially one that doesn't require a lot of headlight bracket modifications?
Name:	LED lights.jpg
    Dec 2016
    Saskatchewan Canada
    Myself and a lot others have these
    https://www.cyclopsadventuresports.c...ulb_p_192.html
    The LEDs line up great with the reflectors inside of headlight
    When I ordered mine, like the link states they were out of stock on the 38 watt and I got the 76 watt. It's amazing compared to factory
    for the fast blink change your relay, easier than soldering in resistors
    https://www.revo-cycles.com/shop/rev...ignal-flasher/
    Active Member
    Jul 2018
    Regarding the LED Turn signals:
    Right on dude, thanks for the tip! Will take a look at where the relay plugs in on my bike, and if it looks like a fit, will order this weekend.
    Regarding the LED Headlight:
    Did you find that the fan housing for the LED bulb made installation difficult, or was it a fairly straightforward install? I've found some H4 Headlights that don't have a fan housing or have the fan housing in front of the round metal plate that claim to avoid the fan clearance issues.
    Dec 2016
    Saskatchewan Canada
    Quote Originally Posted by hoglaw09 View Post
    Had to trim some of the rubber boot and that was it
    Jun 2018
    I ordered the cyclops after seeing it mentioned here a few times. IT IS AWESOME! Mine was a direct fit, no trimming or anything. All I did was completely disassemble everything in the cowl and install the bulb. Took an extra 15 minutes, but everything works as it should. The reason I did this was to get a good grip to be able to "convince" the base to sit in there correctly (lots of elbow grease) When installing the cyclops you need to remove the base of the bulb, install the bulb, secure the base with the metal snap ring, install rubber boot, install power plug. 30 minute job, but I was taking my time. The bulb is too expensive to mess it up.
    Active Member
    Jul 2018
    Hi guys, just a quick update;
    I ended up getting these bulbs for my 2013 M90;
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Primarily, because they were one of only a few H4 LED bulbs that had the heatsink/fan in front of the metal plate, rather than behind. My biggest concerns were (1) having to modify the retaining clip, (2) not being able to utilize the dust/waterproof cover, and (3) getting enough clearance behind the headlight cover.
    So far, so good. I ran the bike at idle for about 15 minutes, while occasionally switching the lamp between high and low beams. No flickering, and it was very responsive. No error codes or signals either, which is good. I had a hard time truly telling if it was brighter than my original halogens, so will have to go take a look at it in the dark. I also angled up the beam a bit, better light up the roadway.
    Will test it at some point this week after work and let you know if these will be a keeper.
    Active Member
    Jul 2018
    Thanks again for the tip on the relay. I ended up buying one on Amazon that had good reviews. I also ordered a rear seat cowl to replace my passenger seat, so will install both at the same time next week.
    Very Active Member MainEvent's Avatar
    Apr 2012
    Northern Virginia
    You should see a huge difference when comparing the Halogen vs LED. If you don't I would return the LED's. I understand your concern about the LED and fan position, but it's not a huge issue. The modification to the clip takes a few seconds. You just have to line it up a bend it a bit to fit around the fan. I bought these LED's for my SUV and they've worked flawlessly. You also have the option of HID's which are brighter and have better beam concentration than LED's. The setup has more pieces, but still a very easy install. If you decide to return your current setup, I also suggest the cyclops. Heard good things about it.
    Active Member
    Jul 2018
    Quote Originally Posted by MainEvent View Post
    Yea, these puppies are legit; I'd been aiming the light from one end of my garage to other, and wasn't able to really get a good representation of the headlight from 10 ft. away from my garage wall. I finally got a chance to make quick spin around the block, and these things are awesome! Really bright, and light up both the road in front of me, as well as give good throw even moving at decent speed. The only complaint I have about them is the beam isn't as focused as I'd like; it has a little bit of a wider spread than I'd prefer. But it's got a great 6000k/6500k brightness and claims 12k lumens, and the kit came with two bulbs, so even if one of them craps out, I'll have a backup.
    Still need to install my newly purchased flash controller to round out this lighting project (i also bought a rear seat cowl that should be coming in this week, so I'll install both at the same time). Hoping the flash controller fixes the hyperflash issue, and lets me run LED's in all four turn signals (running them only in the front two at the moment).
    Dec 2016
    Saskatchewan Canada
    The relay will take care of the hyper flash. I got one when I went all LED signals
    Active Member
    Jul 2018
    Roger that. I got one off Amazon - hundreds of nearly 5 star reviews, so hopefully this thing won't conk out on me in the middle of a ride.
    Pictures of finished product below: clear LED lens caps - 6500k white led's on all four corners - relay installed to remove hyperflash - 6000k led headlight and high beam. The White LED's on the rear are a tad too bright at night, so I might re-visit it at some point (although I don't do much night riding, unless I'm riding back from the metro after a long day at work), and I may swap out the front LED's at some point with these cool nodes that are white for running lights, but flash amber when turning.
    But considering this complete for now.
Name:	Moto Front.jpg
ID:	380470Click image for larger version.
Name:	Moto Headlight.jpg
ID:	380472Click image for larger version.
    Dec 2016
    Saskatchewan Canada
    She's good and bright front and back
    Member busavard417's Avatar
    Oct 2018
    Springfield, MO
    Post LED Project
    Will be starting a facelift project soon. LED's are a major part of the project.
    Found these pictures of 9's with LED's installed under tank shroud.
Name:	Tank Kit - Side by Side (gif).jpg
    Comparing side by side, the 9 on right with blue light has better light effect around fuel cap & speedo.
    Does anyone know best way to achieve this bright effect around fuel cap & speedo ?
    Are strips added close to cutouts from fuel cap & speedo ? Are side view strips added around cutouts for fuel cap & speedo ?
    Suggestions ?
    Thanks in advance.
    Dec 2016
    Saskatchewan Canada
    I'm biased obviously being Blue. I'll be doing some Blue LEDs
  17. #15
    Nov 2009
    San Antonio, TX
    Quote Originally Posted by busavard417 View Post
    Suggestions ?
    Thanks in advance.
    The actual lighting you see coming through the speedometer and tachometer faceplates have to be done by having the LEDs on the circuit boards of each item changed to the color you prefer. Most have had them done by www.bluegauges.com. As for the lighting you see around the edges of the gas cap and emitting from around the speedo cover, that can be accomplished by running either one long strip or two separate strips of LEDs inside of the speedo cover, with the lead wire(s) coming out of the front end of the speedo cover over the neck pieces of the bike.
  18. #16
    Apr 2015
    The Rose; Central Alberta
    Suggestions ?
    Thanks in advance.
    That looks sharp!!
  19. #17
    Oct 2018
    Springfield, MO
    Thumbs up Thanks
    Recontacted a custom shop that installs LED kits on almost everything. I first contacted them to get a estimate on installing a LED RGB wheel kit.
Name:	LED Wheel Kit.jpg
    I was told to add LED strips close to or around the cutouts for the fuel cap & speedo to achieve desired effect.
    @JUDAH-9 I sent my Hayabusa cluster to Bluegauges.com for LED swap out; will be using them again on my Busavard M109.
    Speedgaugecustoms.com is currently working on the Busavard M109 faceplates.
    Will post pic when projects are finished. Though I found out with my Hayabusa, your never really "finished." (unless you sell it)
    Before
Name:	Hayabusa - Avatar.jpg
    "After" - still at shop
Name:	Facelift Avatar - 1.jpg
