Need some help!!!
Results 1 to 8 of 8
Thread: Need some help!!!
    Jul 2018
    Houston Texas
    Unhappy Need some help!!!
    Went for a ride today on my C109R, I blew my horn twice and the entire speedo console shut down, no speedo, no indicator lights, no gas gage, no turn siginals
    no tail or break lights. I still have the headlight. I checked the five or six fuses in the battery compartment, all okay. Is there another fuse bank on
    this bike anywhere, or what else could it be oh yeah and no horn either.
    Very Active Member Acquitted's Avatar
    Jul 2015
    Akron, OH
    Damn, I've no idea. I'd try replacing fuses anyways, you can't always tell by looking. Sounds like a short in the horn circuit, might want to explore that with the millimeter.
    2008 C109RT - ISO grips, K&N Air Filter, NOS exhaust and filter housings, rebuilt driver seat.
    Hammertone powder coat on fenders and tank.
    Plastidip rear frame, sissy bar, side frame covers, and windshield hardware.
    Jul 2015
    Akron, OH
    Multimeter, not millimeter.
    Jul 2015
    Akron, OH
    If the rest of the bike is working fine, I'd try putting a new 10A fuse in the #4 position, and seeing what happens.
    Breslau, Ontario, Canada
    I would guess your horn is grounding on your frame causing a short. Check your horn wiring for damage.
    2009 M109R LE
    2015 Boss tins, Custom speedo and tach faces and LEDs. ISO Grips. Brake Away Cruise control. Cobra Swepts. Debeavered, Fi200R Fuel management, polished risers and trees, SS Brake lines, ATRE, Custom forward controls. HID kit. Ultimate seat and backrest. Dunlop E3s, 250 rear, Plastidipped rims, cobra solo rack
    Have you had the left side bar control apart recently?
    Active Member iwantone's Avatar
    Dec 2012
    edmonton, ab.
    Is it stock or aftermarket horn?
    Nov 2008
    Newmarket, Ontario
    Your horn is on the same circuit as your signal lights and speedo. You definitely blew a fuse, make sure to check again.
    Unless you burnt a wire in the circuit, it should be the fuse.
    Sounds like you hooked up an air horn without a relay?
    You need a relay circuit for larger horns.
    Also , don't put a larger horn in the place of the stock. Its possible to damage the radiator fins with the vibrating.....and it rubbing. Be extra careful.
