Rattle
Results 1 to 19 of 19
Thread: Rattle
    Active Member
    Mar 2018
    Atl
    Default Rattle
    I have got a rattle that is driving me nuts. I sat down and tightened for about an hour not finding anything loose and it is still happening. I only hear it on decel but it's a metallic rattling.
    Or I wonder if I'm just going crazy? Anyone know if a rattling sound is first sign of insanity?
    Dec 2016
    Saskatchewan Canada
    where is the noise coming from?
    Jan 2009
    Fergus, Ontario, Canada
    Quote Originally Posted by atlsrt44 View Post
    Is it possible that is sound from your clutch dampening springs? Does it
    do that when you depress the clutch lever even when you are at rest??
    Active Member
    Mar 2018
    Atl
    Nope. It appears to be doing it clutch out on decel. Best I can figure Is engine shifts on decel and is maybe rubbing against a heatshield or something. Taking it to shop on Saturday till I find it.
    Member DBAG109R's Avatar
    Apr 2018
    Queens, New York
    Mine had the similar sound, turns out it was a metal bracket on the rear fender plastic. Its between the splash guard and rear fender. I changed my tailight and forgot to tighten this metal bracket so it was making this annoying noise.
    Maybe this helps figuring out problem
    Member geosidey's Avatar
    Apr 2016
    scotland
    I had a similar rattle a while back, turned out to be one of the little rubbers on the heat shield of the exhaust had decided it had enough and left so the tab would vibrate at certain revs and was really f***ing annoying until I found out what was causing it
    Active Member
    Mar 2018
    Atl
    Found it... snapped clean. If you cant see it's the bracket on the top exhaust pipe towards the rear.
    Member octane orange's Avatar
    May 2017
    deltona
    I had something sim-miler ended up being gas cap flap for key just a thought?
    Active Member
    Mar 2018
    Atl
    Muffler heatshield. Sheared clean off
    Active Member
    Mar 2018
    Atl
    Dealership said suzuki might fix it under warranty
    May 2006
    If this is a new bike still under warranty they better cover the repairs ..it is afterall either poor workmanship and or poor quality materials!
    Dec 2016
    Saskatchewan Canada
    crap components
    A few weeks ago I went to lock my helmet on the lock and it moved. I'm like WTF so grabbed it and it fell off. Completely sheered off and I hadn't been anywhere near it with mods
    Active Member
    Mar 2018
    Atl
    It's a 2017. About 3 months out of warranty.
    Active Member
    Mar 2018
    Atl
    Just dropped bike off at dealership and now they are saying suzuki probably isn't going to warranty it...
  17. #15
    Active Member
    Mar 2018
    Atl
    So an update. Dropped bike off at mountain motorsports on June 23rd. My claim is now on the 3rd persons desk and we are over 1 month in to replace a $200 part...
    Suzuki cant seem to decide whether to fix it or not and just keeps asking for more pictures and transferring it to someone else.
  18. #16
    Active Member
    Mar 2018
    Atl
    Got a call from dealership today. Suzuki said they aren't going to fix bike because I'm 4 months out of warranty and the part is only cosmetic.
    I told the dealership fine fix it. $225 for the heatshield.
    They call me back and said it's on back order and it doesnt say when it will be available.
    Not too fond of suzuki right now
  19. #17
    Jun 2017
    Florida
    If it is a heat shield on your exhaust you can fine people selling the entire stock exhaust for around $100.00.
    Don't think I would pay $225 for a piece of a stock heat shield, I would put that $225 toward purchasing an aftermarket exhaust before I did that.
    Suzuki is obviously not going to warranty your bike anymore.......so forget about that stock crap and let the modding begin.
    BCS
  20. #18
    May 2006
    BCS
    completely.
  21. #19
    Active Member
    Jun 2016
    West Sunbury, PA
    I had a heat shield bracket break off on mine where the lower pipe extends aft of the collector. Luckily, I was at work... and I have a TIG welder there that I can play with.
    '09 M90 - Current Status: waking the dead.
