Front Fork help
Results 1 to 11 of 11
Thread: Front Fork help
    Active Member pjs's Avatar
    Sep 2012
    nassau ny
    Question Front Fork help
    Hello all does anyone know what the stock length of front fork springs are also anyone know where i can buy good pair of springs my front right is leaking so not sure if my front was lowered i know 10 yrs ago i had a shop do a 2 in drop but dont know if he did springs in front also any help would be greatly appreciated.
    2007 M109R Avon heated grips sumoX fat tire kit sumoX custom paint dual K&N ram chargers kuraquian zombi pedals hydraulic clutch lever,demon eye head light,cobra dragster exhaust and programmer . People honking and giving thumbs up priceless
    Very Active Member "Hunter"'s Avatar
    Sep 2011
    Belgium
    FORK SPRING
    • Measure the fork spring free length.
    • If it is shorter than the service limit, replace it with a new one.
    Front fork spring free length:
    Service Limit: 391 mm (15.4 in)
    page 367 of the service manual
    "Hunter"
    Suzuki M1800R - no rules great fun
    Jun 2017
    Florida
    Here you go, these pictures are just the springs.
ID:	377121   Click image for larger version.
ID:	377129   Click image for larger version.
    Jun 2017
    Florida
    These are pictures with the PVC Extensions inserted in the spring.
ID:	377145   Click image for larger version.
ID:	377153   Click image for larger version.
    Jul 2008
    Forney, TX
    How does the pvc piece stay in the spring without popping out?
    Jan 2009
    Nitra, Slovakia
    Maybe this video will help to answer your question...:
    https://youtu.be/14sSacYg1yA?t=11
    Very Active Member Weedahoe's Avatar
    Aug 2014
    Albany GA
    I have a set of springs if you are still looking for a set
    Jun 2017
    Florida
    The stock pvc pieces actually neck down so the pvc stubs into the springs, but when you put the aftermarket springs in you are really just using 1 inch pvc and it sits on top a washer on top of the spring.
    Really no place for it to go, the dampening rod runs up the middle of the spring and PVC.
    OP I have the stock springs and stock pvc spacers you see in the picture available also if you need them.
    Just PM me.
    BCS
    Jul 2008
    Forney, TX
    Just PM me.
    BCS
    Ahh, ok. I see now, i wasnt thinking about the washer actually being the base for the pvc.
    Dec 2016
    Saskatchewan Canada
    Question on this. Have 21" wheel and love it that it lifts the front end up and I don't scrape forward controls anymore. Thing is with the setup without the 6 degree triple trees i have damaged a small bit on the fender hitting the lower bolt under the headlight bucket. I'd like to keep the extra height and not hit fender by adding new springs
    Jun 2017
    Florida
    I used to bottom out the OEM springs all the time.
    Installed 1.1 kg springs and its much stiffer now......I like it much better.
    https://www.meancycles.com/store/par...?partID=226110
