Kuryakyn Grip Install
Page 1 of 7 1234567 LastLast
Results 1 to 30 of 209
Thread: Kuryakyn Grip Install
    Default Kuryakyn Grip Install
    I ordered the 6235 ISO Grips and the 6250 Throttle Boss. The 6235 comes with 2 grips, glue, instructions, and a small plastic tube about 1.5" long and 1" in diameter. NOTE: The new grips do not come with an allen wrench to remove the end caps.
    Heres a picture of what you will end up with afterwards just for reference (note, old clutch grip is not in picture, I had already thrown it out)
    Throw out the 1.5" plastic tube, it is not needed and just confused me at first. I also threw out the glue and used Gorilla Glue. I wanted a little more time before it set.
    Throttle Side NEW Grip that has a plastic tube fixed into it.
    1) Tap off chrome end cap. I used a flat blade screw driver and hammer and very lightly tapped. It comes off pretty easy.
    2) Loosen the throttle cable adjuster and remove the 2 screws in this pic:
    3) Remove the lower half of the starter switch cover and set aside
    4) Remove the Philips head screw to completely remove the starter switch assy (NOTE: I do not have a pic of this but it's pretty easy to figure out once you complete step 3)
    5) Lift off the starter switch and push to the side
    6) At this point you will see where the throttle cables hook into the throttle. If you look at the second pic at the top of this thread you will see the end of the throttle tube. You should be able to pull the throttle cable out of the hooks. I used a small pair of smooth needle nose pliers. If you loosened the cable up in step 2 this should be pretty easy. I removed the rider side first and then the brake handle side.
    7) Remove the old grip.
    Slide on NEW Grip
    9) Re-hook the brake side cable
    10) Re-hook the rider side cable (this one was a bit of a pain but if you take your time it should pop back in)
    11) Re-assemble the starter switch assy. 1 screw, then the 2 screw cover plate on the bottom.
    12) Re-Tighten the throttle cable.
    At ths point I installed the Throttle Boss.
    1) Remove the NEW grip end cap via the 4 allen head screws
    2) Install the Boss between the handle and the trim ring.
    3) Using the 4 longer screws (provided with the boss) lightly tighten the end cap
    4) Adjust the boss to a comfortable position
    5) Tighten the 4 allen head screws
    Step back and compare the old vs new:
    Clutch Side, NEW Grip that does not have a plastic tube in it:
    1) Cut off the old grip with a sharp knife.
    2) Using a flat blade screw driver or a large open end wrench and a hammer lightly tap off the end cap. It comes off pretty easy so just tap it off.
    3) Remove the chrome trim ring
    4) Clean off the old glue. I used a little alcohol and some sandpaper.
    5) Remove the end cap from the new grip. Use an allen wrench and remove the 4 screws from the end.
    6) Apply glue to inside of NEW grip. You should apply the glue to what will be the "inside edge" of the grip so that as you push it on the glue slides down the rest of the inside. I used Gorilla Glue so that it would give me a little more time to set it on.
    7) Slide grip on and align the rubber where you want it. I set the rubber grip on the top and bottom, it felt most comfortable and matched the alignment of the throttle side.
    Wipe out any excess glue from the end of the grip
    9) Re-install the End cap using the 4 allen head screws.
    Stand Back and look at the new grips:
    EDIT: Apologies to anybody looking for the pictures. I haven't been here in ages and had killed the old host I was using. These should be good for a long while.
    M109Riders Founder Lamonster's Avatar
    Springfield MO
    Default Re: Kuryakyn Grip Install
    Installed the iso grips last night, took about 45 minutes start to finish. Start on the throttle handle first as that side is the fixed side for the rotation of the grip.
    Loosen the throttle cable, take out the 2 screws that hold the control module in place and remove the rear return cable first. After that the other cable basically falls out. Install the new grip, setting the forward cable in place first and then set the rear cable in place. Reinstall the controller screws with a little blue thread lock and then readjust the throttle cable. I would also start the bike to make sure you have not tightened the throttle cable to much causing the bike to rev.
    Once you have finished the throttle grip, pop off the left bar end (it's only a plastic piece held in place by friction) then slip a long thin flat head screw driver under the grip and work the old grip off. The plastic ring by the headlamp switch will slid right off. Take some 200-300 grit sand paper and remove all the left over glue and to roughen up the handle bar for better glue adhesion.
    I found the the little sleeve that fits inside the left grip needs to be cut at 3/16" to 1/4" in length and then inserted into the end of the grip. Test fit the grip to make sure you have it set in the correct position. I aligned the grip to match the throttle grip and place a piece of tape on the headlight controller as a reference when I put the grip on permanently. Wipe off the handle bar with alcohol and then apply the glue supplied with the grip. Start to slide the new grip onto the handle bar and don't stop rotating and pushing the grip until you are satisfied with it's position. Once you stop pushing/rotating the glue will set up almost immediately.
    Good luck and enjoy the new feeling. A great improvement.
    I used the same grips and only have one question:
    I didn't use the plastic sleeve that came with the new grips, nor did I replace the plastic sleeve that was in the stock grip. Should I have used either one? Everything fits and works fine.
    Best $50.00 upgrade out there in my opinion.
    I didn't use the short plastic tube, The new Throttle grip (if you got the same part number) came with a tube in it so correct, there was no need to do anything with the plastic tube in the stock grip.
    Just started to put my new grips on today, and those bastards at the factory (or the dealer, while they "prepped" the bike) decided to overtighten one of the phillips on the throttle side screws, so I stripped it. Now I have to remove the screw before I can continue with this mod. Hopefully I can find another screw in my garage to put back in there.
    I also purchased the brake and clutch pedal covers. It is pretty weak how the instructions from Kuryakyn tell you to use electric tape to make a good fit, and then glue the peg cover the the peg. That is quite a cheesy way of installing a peg. Also, the little allen screw is worthless in securing the peg cover to the peg. Not too impressed with that product. The peg cover won't stay secure and I am not sure how I will solve this, except drilling a hole in the peg itself for the allen screw to go into.
    Hopefully the grips work out better.
    chadrob30
    Guest
    Me too. Now I'm stuck with a half disassembled bike and no way to get the screw out. How did you get it out on yours?
    The screw that gave me trouble was not crucial and I could still use the bike. But I wound up using a screw-removal bit that was slightly smaller in diameter than the screw and carefully drilled up into the screw which eventually made it break apart. Found a very similar screw at a hardware store to replace it with. No problem.
    Hardly Davidson
    Guest
    At least you guys are smart enough to install the throttle side first so that you can get the design of the grips to align symmetrically. Seen some installs that don't quite look right. Those must be the people who drink the kool-aid.
    I installed the new grips and the throttle is sticking. The idle is fine. I'm not very mechanically inclined. Any suggestions would be greatly appreciated.
    Quote Originally Posted by rdnktx25
    Did you re-tighten the throttle cable that you loosened to get the factory grip off ?. If that cable is not tight it won't "snap" the throttle back
    The cable was adjusted properly. Ive been thinking all day and I know what I did wrong. I nicked the handle bar just a little bit while taking of the end cap on the stock grip. That is what is causing the sticking. I'm going to take the grip back off and smooth out the handle bar. I hope I didn't ruin the rubber on the inside of the grip. If so I will have buy another set. Thank you for attempting to help, hopefully it wont be a fifty dollar lesson. This is my first bike and needless to say I've got alot to learn. This site has been a tremendous help.
    Jun 2006
    Thanks for the how to, really made the job easy. I used the Gorilla glue you recommended and it worked great. But how do you get it off of place you don't want after it dries. There's some on the handle bar between the grip and signal housing and on the side of the signal housing. I think I used a little too much.
    Small blade, I used an x-acto knife to CAREFULLY clean it up.
    Jun 2006
    Darn Phillips screw tricked me too.
    I do not know how they managed to tighten it soo much without ripping off the head.
    Now I am here with a screw that does not budge.
    I think some WD40 and maybe hammering a slit into it might give a better angle of attack...
    We will see.
    Phantasy is our only weapon to battle reality!
    I used the screwdriver and pliers in the, ahem,..."tool kit" to remove the screws I pushed up on the screwdriver handle as hard as I could with the palm of my hand and turned the screwdriver with the pliers. It made a popping noise when it let go, kinda like the bolts do that hold the cowl/pillion seat on. There's no way in heck that screw should have had that much torque applied to it ::) I also dremeled the teet off of the headlight/blinker assembly and moved it so I could turn the clutch handle up a little without hitting the "pass" button. It's been like that for a couple months and hasn't worked loose yet
    Jul 2006
    I'm starting to wonder about Suzuki's Quality control...Screws that are overtightened and nuts falling off the blinkers to Wheels put on backwards...I hope Suzuki is visiting this site to see what we are talking about and then do something to fix it...
    Very Active Member sboden's Avatar
    Sep 2006
    Kansas City
    This will be my first mod. I loved these grips on my previous bike. The throttle body worked great for my long bike trips. Thanks for the step by step instructions. They are as good as the one on my previous bike's forum.
    Sold my beautiful Silv M109R for a more practical Concours 14
    I just did mine tonight. Great directions.
    1 thing. I used the glue that came with it. Unless you are really weak it is fine. It did not set instantly. It's about 70 degrees here now, I dont know if that helpoed.
    I did use a little tape on the control so I knew where to line up the left grip.
    Just be sure you removed ALL the old glue and the new grip should go right on
    Sledzep
    Very Active Member 2006moy's Avatar
    Jul 2006
    Instead of using tape thats what that little throw away tube is just cut a small piece off and your grips will have the right lenght install.. i used a tape measure in the old grip from end to opening then did the same on the kurys the difference is what i cut that little piece of tubing worked perfectly.
    Jun 2006
    One little tip that might be helpful:
    Not only loosen the throttle adjuster, but turn it all the way INSIDE the throttle box.
    So the throttle cable will come really loose and it will be no problem to remove it.
    After the install just turn the throttle adjuster back to its old position (as visible in the pictures above) around 1 cm from
    the throttle box.
    Very Active Member Boar's Avatar
    Salina,KS
    Yep same problem here with the screw, time for hammer trick hope it works
    Salina,KS
    Cant get that damned screw out at all tried tapping it with a hammer and no luck :realmad:
    Seasoned Member seapup's Avatar
    Jul 2006
    Lake Ridge, VA
    Quote Originally Posted by Boar
    Use an impact driver, either manual or impact drill combo.
    How-to: http://www.motorcycle.com/how-to/how...crews-3440.htm
    Some sources:
    http://www.sears.com/sr/javasr/produ...id=00947641000
    http://www.globalsources.com/gsol/I/...1002747873.htm
    Oct 2006
    What about applying a little heat to it before you try backing it out ?
    Jul 2006
    Lake Ridge, VA
    Quote Originally Posted by dozer46158
    Heating it will reduce the strength at the head first which means the head will probably shear off before the thread end releases.
    Salina,KS
    I got em on finally, had to act like a was a watermelon redfaced then put as much upward pressure I could with my palm on the screwdriver and got it finally, got both sides on only problem Im having now is the turnsignal assembly when Im putting it back together the seams to the top and bottom part are not fully touching doesnt seem to be anything abstructing the pieces that I can see. Thought maybe I had a wire hung up or somethin tried it about 5 times now and doesnt seem to want to meet up grips look great that signal assemblys bugging me though
  30. #28
    Jul 2006
    Lake Ridge, VA
    There is an alignment pin on the assembly/housing that has to match up with a hole drilled in your bars, unless you dremelled the pin off to raise/lower your bars.
  31. #29
    Salina,KS
    Seapup that was it guess I got in a hurry and didnt notice that appreciate the help
  32. #30
    Very Active Member TonyRumble's Avatar
    Punxsutawney PA
    Just got mine on.. super easy to install. I'm glad i didn't have the issues with the screws some other have had.. waiting for the glue to dry and it will be all done. the only thing I'm not so sure of is the play on the throttle side. I know there was some in the stock throttle. but i can't remember if it was this bad or not. i did adjust the cable so the throttle up and down play is ok. it's the side to side play that feels weird. anyone else have this??
