Need tire advice
Results 1 to 30 of 30
Thread: Need tire advice
    Very Active Member Acquitted's Avatar
    Jul 2015
    Akron, OH
    Default Need tire advice
    After 11K miles, the front Bridgestone Excedra Max tire is ready to go to tire heaven. Funny, the rear has ~8,000 miles, and still looks brand new.
    In any case, I liked the Excedra Max a lot, and can't complain about the mileage, but shelling out $180 for a new one seems high.
    There aren't many options for front tires in our size, but there are a few bias ply options at half the price. Anyone have first hand experience with those?
    2008 C109RT - ISO grips, K&N Air Filter, NOS exhaust and filter housings, rebuilt driver seat.
    Hammertone powder coat on fenders and tank.
    Plastidip rear frame, sissy bar, side frame covers, and windshield hardware.
    Active Member Hawkie's Avatar
    Aug 2013
    Adelaide Australia
    I have one of these ready to fit
    Shinko 230 Tour Master Front Tire 150/80H-16
    Dec 2016
    Saskatchewan Canada
    You can actually go up in size to a 160 on the front. Maybe you can find a better deal on a larger tire.
    A lot of people including myself have the 160 and it makes a difference on crappy roads. I'd never go back to the 130
    Sent from my SM-N920W8 using Tapatalk
    Jul 2015
    Akron, OH
    Quote Originally Posted by Hawkie View Post
    Yes, that is one of the tires I've seen on Amazon for less than half the price of the Excedra Max. But it is a bias belt, not a radial, and I don't know what that means in terms of ride quality, noise, grip, and treadwear.
    Any experience/advice on this?
    Jul 2015
    Akron, OH
    Interesting thought, though I have the C, which has an OEM size of 150/80 - 16. Maybe different from the M? There's not much clearance between the tire and fender, half an inch or so at rest, and not sure how much bigger I could go without rubbing at highway speed and beyond.
    Is anyone successfully running a larger front tire on the C?
    Dec 2016
    Saskatchewan Canada
    Quote Originally Posted by Acquitted View Post
    Sorry
    My bad
    I'm on tapatalk right now and didn't notice it wasn't an M
    Aug 2013
    Adelaide Australia
    I was never happy with the OEM bridgestone on the front, the tire that was on it wore on one side as they do and it was crap on the road, A new oem felt far better until it stated to wear a bit.
    When the rear wore I waited months for Bridgestone Japan to do a run, I ran out of time and tread and went for a Metzler 240/50-16 which is slightly smaller in rolling diameter, stock 240/55-16 and I will never go back, the difference was amazing and completely made the bike so much easier to turn.
    I havent put it on yet, I did read a heap of reviews and they seem to be great for grip and not too bad for wear.
    dig deap enough you will find they bought all of Yokohama's designs and Techknowledgy but now made in South Korea like so many brand name tires are now.
    here oz a oem is nearly $300 the Shinko under half that delivered from the US so I think its worth a try, after all the C109 is not a street racer and the ratings are fine
    Jul 2015
    Akron, OH
    Alright, let's roll the dice together, the Shinko it is. Let's compare notes in a few months.
    Active Member PECoachK's Avatar
    Oct 2017
    River Grove, IL
    I have shinkos on my Busa, very happy with them.
    Sent from my Pixel XL using Tapatalk
    2006 Blurple M109R
    Jul 2015
    Akron, OH
    I'm sure they make a solid tire, I was mainly looking for wisdom around what would be different moving to a bias ply v radial, and also what handling characteristics might change in running a mix (Excedra Max radial in back, and Shinto bias in the front), as the rear tire has another 5K of tread left, at least.
    I ride 5-6K miles per year, 80% of which is 80mph highway cruising. The rest is puttering around town, with a few excursions along the way looking for twisties. I haven't seen anything concerning in any review, so I'm taking the plunge. I'll likely have the new tire mounted by next week, and as soon as the s**t Ohio weather breaks, I'll see what happens.
    Jul 2015
    Akron, OH
    Got the Shinko front tire mounted, and was able to put 80 miles on them yesterday.
    Maybe I just need to get my sea legs back after two months of winter weather and no riding, or maybe it was strong cross winds, but I gotta say that at freeway speeds, the front felt like it was doing a bit of dancing, and not in a good way. Felt OK until 65 mph, but between 65 and 80, it felt like I needed to put in a lot of input to keep the bike straight and upright. Not a balance issue, not a wobble, no vibration, just drifting. Not confident inspiring.
    In any case, looks like at least two more weeks before I'll be able to ride again and see if it gets better.
    Mar 2013
    Calgary, AB
    You should not mix Radials and Bias Ply tires. The Bias ply will tend to want to follow ruts in the road where the radial will not do this. It's probably what you felt at 65 MPH. It is definitely not recommended or safe IMO
    R
    Apr 2017
    St. Louis Missouri
    Nothing wrong with putting a bias on the front and a radial on the back, that is how I am running now. Have the Commander II on the front of my M109. The Dunny Elite 3 250 on the back.
    Marty
    Jul 2015
    Akron, OH
    Got out again today for 40 miles, it felt fine all the way up to 90 mph. Must have been the wind on Friday, or the 100 mile break-in.
    Triumph and the MoCo both specify a radial/bias mix for several of their models, there's nothing intrinsically unsafe about it.
    The Shinto up front definitely has a different feel on the C compared to the Excedra Max, more communicative through the handlebars, and quicker turn in, both of which will take some getting used to. But beyond that, it didn't feel unsafe or unstable at all today like it did on Friday.
    I'm going to give it a few more hundred miles. Stay tuned.
  17. #15
    Jul 2015
    Akron, OH
    I'm going to call the Shinko experiment a failure. I put a few hundred more highway miles on the bike over the past few weeks, and the phantom drifting is back. It is just fine at low speed, but at any speed over 65, it feels like there's an invisible toddler randomly yanking on the handlebars. Goddamned terrifying.
    I took advantage of a righteous price plus a 20% off everything deal on eBay, and ordered another radial Excedra Max. Hopefully that solves the problem, though with another 2 inches of snow on the ground today, it may be a while before I can confirm.
    Some folks have done this successfully, and YMMV, but for me it felt unsafe, certainly not worth the ~$65 difference in price.
    That said, anybody want to buy a very lightly used Shinko 150/80-16 bias ply front tire for dirt cheap?
  18. #16
    Aug 2013
    Adelaide Australia
    disappointing to hear that as the tire I bought many months ago will be fitted shortly
  19. #17
    Jul 2015
    Akron, OH
    Another follow up...
    Because swapping tires is a pain in the ass, I actually kept the Shinko on for another 500 miles or so. No change, still sucks.
    I finally got to my dealer today to get the Excess Max mounted, and voila! Right out of the gate, a noticeable improvement in handling and stability. Got it up to 95 on the freeway, and just as stable as if it were on rails.
    YMMV, but I for one will never try another bias tire on this bike, and don't recommend it for anyone else.
    But if you do try it, please post your experience here... I'm curious, maybe I simply got a bad Shinko tire.
  20. #18
    Nov 2008
    Newmarket, Ontario
    Once your tires get overly worn, especially if flattened out, any new tire is going to feel remarkably better right away.
    I found the bridgestones were the best options for the C.
  21. #19
    Aug 2013
    Adelaide Australia
    Quote Originally Posted by BradSmith View Post
    Acquitted was talking about a new Shinko tire.
    As for the Bridgestones I went to a Metzler for the rear as there were no Bridgestones in Australia and the were waiting for a batch to be made and I gave up after waiting for 3 months for a tire.
    As you would be aware the C is the only bike in the world to use a 240/55 16 tire and only Bridgestone Japan make them.
    I went for the 240/50 16 as it was the closest tire made and up for the job as it also fits the Triumph Rockeet 3 and liked the reviews the Metzler got.
    It was a instant improvement on the Bridgestone as it no longer had issues with groves and ridges in the road and it turns in much easier and smother with less trying to stand the bike up.
  22. #20
    Nov 2008
    Newmarket, Ontario
    I tried that tyre once, added revs on the highway. Went back to the Bridgestone.
    Sent from my Pixel 2 XL using Tapatalk
  23. #21
    Jul 2015
    Akron, OH
    I agree. Nothing but Bridgestone Excedra Max tires on this bike from now on. I know a lot of folks like the Metzlers, but they cost 30% more, and the Bridgestone are just fine.
    I'm going to turn the Shinko into a tire swing on the kids swing set, LOL.
  24. #22
    Jan 2018
    Geelong
    I heard the other day that Shinko tyres are actually Michelins. Is that true?
    Sent from my SM-G950F using Tapatalk
  25. #23
    Mar 2013
    Calgary, AB
    Maybe some manufacture's mix bias and radials, but Suzuki does not. I was in the tire industry with Goodyear for 25 years. A reputable tire shop will not install radials and bias ply tires on the same auto because it is dangerous! A bias ply tire will follow the ruts and curve of the road and the radial will not. I am fairly sure that is what you experienced with the bias ply on the front and radial on the rear. I'll bet it was scary at highway speeds. Glad you got it figured out.
  26. #24
    Apr 2018
    Missouri
    Quote Originally Posted by Disco Turtle View Post
    Michelin is a totally separate company. They only sell motorcycle tires under their brand. You may be thinking of Yokohama. They got Yokohama's molds in 1998.
  27. #25
    Aug 2013
    Adelaide Australia
    Shinko a Korean co that bought all Yokohama's techknowledgy and patterns for motor cycle tires.
  28. #26
    Aug 2013
    Adelaide Australia
    Quote Originally Posted by Fishman349 View Post
    Not something I would advertise
    goodyear with a dodgy factory that makes killer tires
    https://www.google.com.au/search?q=g...hrome&ie=UTF-8
  29. #27
    Jul 2015
    Akron, OH
    Final follow up. I found a good use for the Shinko, one that won't try to kill me. The new owners have reported no issues with handling at speed.
  30. #28
    Mar 2013
    Calgary, AB
    I did not even know that Goodyear sold motorcycle tires and have never seen them here in Canada. I sold Auto tires and Goodyear was always the innovator in tire technology ie: the first ever rain tire and ice radial, so I think I will still advertise it.
  31. #29
    Feb 2018
    Langley,BC
    Arrow My Tires
    Hi. These R my findings. U might find what I say different.
    I used a Bias ply on my bike and when it wore out I switched back to a Radial.
    You'll notice a difference in handling for sure. On grooved pavement or bridges and uneven surfaces even moving from side to side on pavement that has just been laid on one side of the road. A Radial tire takes up some of the discrepancies in handling on the road to give you a smooth ride.
  32. #30
    May 2006
    Here's a bit of info about radial vs bias ply in a type of simplified summary of a head to head comparison that is easily understandable.
    https://agricultural.michelinman.com...e-right-choice
