Additional buttons disaapeared - Page 2
Page 2 of 2 FirstFirst 12
Results 31 to 39 of 39
Thread: Additional buttons disaapeared
  1. #31
    Aug 2007
    Montreal subburb
    Well I downloaded the latest IE 11 for my computer again, and it downloaded the same I had before:
    So 'Google Custom Search' just shows blank white page
    instead of an answer and stays that way until I turn it off...
    OH OH , I'm a BOOB ...m
    my results in post #23 were using the search tool at the top of the page
    now I see you are using the "'Google Custom Search' " tool , at the bottom of the page .....
    Oh man, I'm sorry I made you do all that work ...
    I just tried the Google search at bottom , and it never stops turning , just like yours Evil.
    that different IE version will not help you one bit.
    the different version could be because my Win 7 is a french version ...
Name:	IE version jan. 2018.jpg
    Every Time You Lift Your Tank Beware Of This .
  3. #32
    Jan 2009
    Fergus, Ontario, Canada
    Quote Originally Posted by Kazimodo View Post
    Thanx Kaz!
    I learn every day, and 'IT' stuff is an Spanish language to me anyway...
    I hope this will help the moderators to troubleshoot the problem...
    Did the search tool on the top give you answers only related to this forum?
    Because the bottom one (Custom Google search window) used to do specifically that.
  4. #33
    Jan 2009
    Quote Originally Posted by M109R admin View Post
    Thanks for bringing it to our attention! This is actually a known issue (Case #2851755) and is likely related to vB4 software (again). This same issue (specifically with Google custom search) is showing up on a couple other vB4 sites as well. The tech team is on it and will hopefully get things resolved soon.
    Cheers,
    Erik
    Eric,
    it doesn't look like it had been fixed. My Win 7 with IE 11 used to function, but it doesn't anymore.
    Thanx.
  6. #34
    Aug 2007
    Montreal subburb
    The one at the top searches this site only from what I can see ,
    I wrote "garden hose" , ended up with 3 pages of threads ,
    in any thread, if the words " garden hose" are present , even if only in one of the posts
    that thread will in the search result , ex: I had to go down to post #15 in a thread , the words " garden hose " were there ,
    they were highlighted in yellow ,
    it is like that as long as you surf thru the pages that came up in the search result pages.
  7. #35
    Administrator M109R admin's Avatar
    Sep 2013
    Hey there,
    As Lee said, we really don't recommend users on Internet Explorer.
    If you were to try Chrome, there is a big difference.
    Give it a try and let us know how it goes.
    Ed
  8. #36
    Aug 2007
    Montreal subburb
    No complaints here , the search engine at top works for searches on the site here ,
    if I ever want a search of the whole web , i just open a second browser and use Google .
    during the night Jan. 9th to jan.10th , Windows Update did a few Updates ,
    I just tested the Google search at bottom of page , and the Windows updates did not change
    anything to the results , never ending white page . I search at the top still works very well.
  9. #37
    Jan 2009
    Hey there,
    Ed
    I tried, no success. Not even able to open M109Riders.com, tells me something
    about unsecured website.. Any other websites I have no problem to reach.
    Win7, IE11.
    Viliam
  10. #38
    Sep 2013
    I'm finding, even with other browsers, that Search Bar is a little unstable. When I try and use it, at first I get no results. Refreshing the page fixes though, with all the results showing up.
    With IE, I have found a work around for the White Page error when you try and use. IE has a "Compatibility Mode" you can access, which helps sites integrate with Internet Explorer better. If you got to the top right menu button (the one shaped like a Gear) you should see the "Compatibly View Options". Open that up, add the site to the list, the page should then refresh and you should be good to go (though I still ran into the same bug as I've been having on other browser). Give that a try
    For the general unstable nature of that search bar: Case #2893872
    Kevin
  11. #39
    Jan 2009
    Kevin
    Thanx, Kevin, I went there and M109Riders.com
    had been added there forever ago, still doesn't work....
    Viliam
