Bike running sluggish in 1st and 2nd gear
Results 1 to 5 of 5
Thread: Bike running sluggish in 1st and 2nd gear
    Active Member Jaymann's Avatar
    May 2013
    Houston Tx
    Default Bike running sluggish in 1st and 2nd gear
    On my Bike today and everything was fine,all of a sudden I noticed when I go to take off the bike is kinda sluggish in 1st and 2nd gear. Any ideas on what's going on?
    John's 2 1/2 lowering bones,ISO grips w/stiletto tips,debeaver,debadged,Hard Khrome side burner exhaust,ATRE, LEDs and HID headlight
    Very Active Member stormiezzz's Avatar
    Dec 2014
    Cape Town
    Hi there
    I think you are going to have to provide more information like;
    When last did you service the bike?;
    What mods do you have?;
    Power commander installed?;
    Etc.
    Once you have provided the normal usual info as per above requirements then guys will be able to chime in and assist with a diagnosis via a process of elimination.
    Good luck with getting it sorted buddy.
    "RIDE IT LIKE YOU STOLE IT"
    May 2013
    Houston Tx
    The bike was checked out a couple of months ago at the dealer and everything checked out fine. I did notice that my clutch lever was not fully going back into it's normal position after I switch gears and release. It could be just a cable needing to be adjusted. The characteristics the bike was showing me when I take off is as a clutch would be going out on a car.
    I've put on the side burner exhaust years ago and that's it, never had any problems until now. The bikes a 2009 and has 10k that kinda shows how much I ride.
    Jul 2008
    Forney, TX
    Quote Originally Posted by Jaymann View Post
    Dont judge by the clutch lever going back. It should move a little when under load. The slack will be taken up a little. You dont want it to be too tight. Thats how the cable snaps.
    Active Member
    Jul 2018
    You ever figure out a solution to this? I was getting some juttery movements in 1st and 2nd for a little while, but dumped about 8 oz of Chevron's fuel system cleaner, and my bike is running much more smoothly.
    Riding a 2013 M90 with almost 11k miles on my end (i purchased used a few months ago with 10.3k on it, and have only put on a few hundred miles on my own, but figured our motors were in about the same shape).
