Hypercharger vacume splice help??
Results 1 to 7 of 7
Thread: Hypercharger vacume splice help??
    Member Contortzz's Avatar
    Jun 2015
    Australia
    Default Hypercharger vacume splice help??
    Hey just lookin for the correct vacume lines to T splice and connect to hypercharger pro r duel set up only one line looks correct gauge but Im a novice at this ****... is it the one in my pic below or can some post pic of correct one. This is on both sides kinda looks like it....
    Sent from my SM-G928I using Tapatalk
    Jun 2015
    Australia
    Think its these ... goin to search some more yhen give it a go...
    Apr 2014
    Chesterfield, VA
    Check out my build thread. (Link in signature below)
    i have several pictures posted of where I splice into the vacuum line.
    Apr 2018
    Bronx,ny
    Hi. I am looking for the link so I can install the hypercharger. Do you still have it?
    Very Active Member Hogan109r's Avatar
    Dec 2013
    Myrtle beach sc and cornelius nc
    Quote Originally Posted by Akiraspoison View Post
    It’s right under his picture of his bikes
    “ To the nines build “ tap on that
    Apr 2014
    Chesterfield, VA
    This link will take you to the post for the vacuum lines.
    https://www.m109riders.com/forums/sh...=1#post3592673
    Jun 2017
    Florida
    Just keep in mind to do a good job when you install the tee's in those lines.
    Those lines connect to your IAP sensors, so if you have leaks its going to throw your fuel maps off.
    BCS
