2010 C109RT EXCVA FI problem
Thread: 2010 C109RT EXCVA FI problem
    Apr 2016
    Toronto
    Default 2010 C109RT EXCVA FI problem
    Hello
    Newbie here, please excuse my inexperience.
    A couple of weeks ago, the FI light came on and off. I checked and its the EXCVA.
    Cleaned the valve on the outside, used wd40 on the spring and cables.
    Light is still on, the servo doesnt move when I turn the motor on/off.
    Can someone (please) explain why this is needed? After-market pipes dont seem to use this valve.
    Is there a way to leave it open and just disable the mechanism?
    Thank you
    Ride safe :)
    Fergus, Ontario, Canada
    Quote Originally Posted by adishi View Post
    Hello
    Thank you
    Ride safe :)
    Your exhaust valve is gone with your OEM pipes. What you have there is servo motor,
    which more then likely failed (plastic gear teeth). I am not sure if your ECU has a #7 wire
    which earlier models M109R-s have, and needs to be cut/removed to stop the signal from
    now failed servo motor. Other option is to buy simple plug-in "Exhaust Servo Eliminator"
    made by (couple manufacturers). In both cases you can throw away whole servo motor
    mechanism after.
    https://www.m109riders.com/forums/sho...=1#post1772459
    https://www.youtube.com/watch?v=FAvKXwRKyR4
    http://www.ebay.com/itm/Servo-Buddy-...-/251259154872
    Apr 2016
    Toronto
    Thank you for the prompt reply :)
    Reading my post I realized I forgot to mention that I am using the original pipes. sorry.
    Any reason why I need this valve?
    This is a C109RT, is that different than the M109 ?
    Do I visit the mechanic or just get the "servo buddy" installed and forget about it?
    Had few bikes since 1995, first time I see this exhaust valve.
    Very much appreciated
    IMHO this explanation is close to the truth, but it is bias because they are selling the "Eliminator".
    http://www.skutr.net/exhaust-valves-...ors-explained/
    I would disconnect the mechanism with/and the servo motor, The butterfly valve in the exhaust
    will stay open because it is spring loaded. That will require the 'servo eliminator' .. But, if you are
    mechanically skilled, you can open the servo motor mechanism, and fix the worn out plastic gears
    inside, by simple flipping the gear wheel 180 degrees and use the good part/side of the gears....
    You will need to pay attention to the contacts parts which needs to be reinstalled adequately...
    Jun 2015
    Brisbane, Australia
    There's a brown/blue wire to the ecu that needs to be removed... I'll have to find more info on this and get back to you... you can use an eliminator which should be ok as well...
    Apr 2016
    Toronto
    Thank you Guys!
    I got the "Servo Buddy" ($100 Canadian), after a quick and easy install bike runs like a charm!
    Much appreciated
    ride safe
    adi.
    Jun 2015
    Brisbane, Australia
    Thank you Guys!
    Much appreciated
    ride safe
    adi.
    Sweet !! :)
