Has anyone successfully installed a tach
Results 1 to 12 of 12
Thread: Has anyone successfully installed a tach
    Default Has anyone successfully installed a tach
    I have been trying to figure out how to fix the bouncy needle issue with the baron tach I installed. Has anyone successfully installed one of these on a 109? Mine is an 08 C109R it bounces at idle and then steadies from 1500 to 2k then bounces from there thru 3k and steadies at 4k and remains steady
    Member mightym90's Avatar
    Jan 2017
    Western MA
    Quote Originally Posted by Cherokee Bill View Post
    Did you use one of these when you wired up the tach? This is supposed to fix the bouncing needle, it's made for fuel injected bikes with single fire ignitions...
    https://www.baronscustom.com/catalog/display/243/
    Yes I did, and it's bouncy because of it. If I hook it up to one coil or the other I read half rpms but it's steady as a rock, I'm gonna buy another adapter and see if it's just faulty. It's on the list of stuff to do but not near the top at the moment
    Sent from my SM-N910T using Tapatalk
    2008 Suzuki Boulevard C109R
    Nov 2008
    Newmarket, Ontario
    Installed a Baron tach on my C109 and carried it over to the 2nd c109.
    Use Single Fire tach Adapter BA-7315-50 to correct the bounciness
    Nov 2008
    Newmarket, Ontario
    Quote Originally Posted by BradSmith View Post
    From memory, I think you have to connect to the 2 main coils, very front and very back of the engine (the other 2 coils may or may not fire depending on whats going on). Using the tach adapter to join the 2 signals without crossing.
    Any tach will do, i had a Baron that mounted on the handle bar clamps.
    Nov 2008
    Newmarket, Ontario
    Some of the install photos in my C109 Mods Album
    https://goo.gl/photos/mwy2zJNve6oSnt327
    I'm confused, does it have more than 2?
    Nov 2008
    Newmarket, Ontario
    There are 2 plugs per cylinder, you will need the adapter to read from each cylinder.
    Choosing the correct coils is important from what another member told me when I first installed in 2008.
    Very front plug and very back plug. And from my picture links below, the wire colours should be visible.
    I don't see any pictures or links
    Nov 2008
    Newmarket, Ontario
    Four posts previous
    Sent from my SM-G950W using Tapatalk
    Jun 2016
    Tampa Bay, FL
    All I see at that link is a single picture.
    Bought on 06/18/2016 for $6,500, with 1,864 original miles on the odometer (and I'm the third owner! Da fuq were the first two thinking?)
    Nov 2008
    Newmarket, Ontario
    Quote Originally Posted by TheRealMoleman View Post
    Link to whole album, sorry
    https://goo.gl/photos/NiZ9w7pepzb28zbP8
