Brake pads
Results 1 to 26 of 26
Thread: Brake pads
    May 2016
    Port st Lucie, Florida
    Default Brake pads
    Since I am replacing tires , I am thinking on replacing the brake pads too ... I checked the front ones and even thou they still work fine , they are getting thinner and I would not want to damage my rotors because these things are hugely expensive , so I will be spending a couple of dollars for the pads and will solve the problem .The rear pads have more meat on them that the front ones but still no too much more , so I guess I will do both .
    The rotors , I will use some 400 sand paper to eliminate any glaze or whatever (they look good to me ) and they will be good to go .
    Now , to the ever incognito question : which type of pads should I get ?
    According to all the search and the reading that I have done , the ceramic pads have less dust , but these pads will eat the rotors fast because as hard as they are . Ceramic is way harder than metal , so consequently , the rotors will wear out faster ... so , I am thinking instead of Sintered pads .
    Anybody agree with this ? I have not ordered them yet , so there is ample wiggle to change my mind and order something else .
    Please, feel free to comment and suggest which ones to get and where ... Thanks so much
    Apr 2016
    Manteno Il
    I bought a set of these and they work much better than stock. I have not noticed any accelerated ware on the rotor after 4,500 miles. http://www.ebay.com/itm/Front-Rear-Ceramic-Brake-Pads-2006-2009-Suzuki-M109R-Boulevard-Set-Full-ac-/162206088999?hash=item25c43c7f27
    Apr 2014
    Chesterfield, VA
    I bought Galfer pads and rotors from TRod when I did my build last year.
    Very Active Member Stavros's Avatar
    Jan 2010
    King City, Ont
    ditto 4 me
    Stav
    May 2016
    Which ones you got , the Galfer sintered or the semi metallic ?
    I would not want noise or hissing or , so I am thinking now on the Galfer semi metallic type .
    Jul 2008
    Forney, TX
    Quote Originally Posted by josey88 View Post
    I have the Galfer sintered front and back. They are a little noisy at first until they get bedded in. Now, they are quiet as a mouse. I might give these a try next.
    Look at this on eBay http://www.ebay.com/itm/151093510704
    Apr 2014
    Chesterfield, VA
    Sintered. No issue with noise.
    Aug 2006
    Okanagan Valley B.C. Canada
    Default Brake pads
    You may also want to check your bearing grease. When we did mine for the first time from factory they were dried out! The dealer gave us a whole new set.
    Sent from my iPad using Tapatalk
    Vegas Meet May 17-24, 2017! Let's bet on a great time!
    https://www.m109riders.com/forums/sho...d.php?t=321882
    Riders Meet 2018, Nakusp BC. Date ?
    Planning stage. Location secured
    Very Active Member izzyg64's Avatar
    May 2015
    Liberty,near Greensboro North Carolina USA
    How often are you guys replacing your brake pads, my bike has 18k and they still look good
    Aug 2006
    Default Brake pads
    Quote Originally Posted by izzyg64 View Post
    I've changed them once, I have over 55,000 km and I just bought a cheep set of pads, depends how much stopping you do, lol I have mostly highway/touring miles. I don't need a new set but I have these on hand for the next tire change. I'll be looking at the bearings again as well. I have no idea if these a good pads or not, the review said they were efffective at stopping the bike, lol that's all I need! Lol we shall see if they are as nice as the Suzuki brand.
    Apr 2014
    Chesterfield, VA
    Changed mine at 8700 miles. The stock pads still had lots of meat on them. I replaced them due the changing the rotors for my build. I also hated how much brake dust there was with the stock pads.
    Active Member cyotee's Avatar
    Dec 2008
    San Francisco
    Default Brake pads
    I swapped my own for EBC HH pads at 2k miles. Much stronger braking - enough to lock the front a little too easy perhaps. But the originals felt spongy and soft.
    Current: 2014 M109R BOSS, 2005 BMW Boxer Cup, 2014 R1200GS, Vespa 300 GTS
    May 2016
    I am getting the Galfer semi metallic pads . I don`t like the dust , but I can clean it up . They are easy on the rotors and there is no noise . I don`t like them I can always replace them with sintered .
    Feb 2012
    I have 78000 ks or 48000 miles on my original fronts , yup, and i have had 5 rear sets. My fronts have 1/3 left still to go. I never was a hard front braker.
  17. #15
    Apr 2014
    Chesterfield, VA
    Quote Originally Posted by SKIDMARK View Post
    There may be 48,000 miles on the rear, but I bet the front only has about 12,000 miles!
  18. #16
    Feb 2012
    Oh yea, i forgot....
  19. #17
    Sep 2010
    McPherson, KS
    I'm surprised you use brakes at all. I thought you were more of a man than that. Like Fred Flintstone.
  20. #18
    May 2016
    Je, je ... that was funny , lol...
  21. #19
    Feb 2012
    He used his feet, weren't you watching?
  22. #20
    Sep 2010
    McPherson, KS
    Sometimes you truly are dense. That was exactly my point. He didn't need brakes because he used his feet.
  23. #21
    Active Member markmacd's Avatar
    Aug 2013
    Nottingham UK
    Default Brembo
    I only use Brembo sintered on all my bikes i have owned. No squeaking, no vibration, good wear and not harsh on the rotors. Pay a little more for them, but Tyres and Brakes are 2 components i dont mess with.
  24. #22
    Feb 2012
    Your attempt at humor was lost on me, i suggest trying a corpse or something closer to your age. In fact, do me a favor, STFU.
  25. #23
    Sep 2010
    McPherson, KS
    Yeah, if I'm older than you, and I don't know that I am, it's like 15 minutes older. Pot, meet kettle.
  26. #24
    Active Member ontherocks2u's Avatar
    Oct 2007
    Westerville, Ohio (Columbus)
    Brake pads are more or less based on weight of bike and riding style. From what I understand. BUT. Which shoe goes on the outside....
    Life Begins On The Edge!
  27. #25
    Jul 2008
    Forney, TX
    Quote Originally Posted by ontherocks2u View Post
    What brand are those? I have Galfer and mine had just the 1 grove on each pad.
  28. #26
    MoCo Maryland
    That's going to make literally no difference!
