M109 tachometer retrofit to C109RT
Results 1 to 7 of 7
Thread: M109 tachometer retrofit to C109RT
    Active Member
    Jun 2016
    Tampa Bay, FL
    Default M109 tachometer retrofit to C109RT
    What is involved in doing this? Is there a tutorial written up somewhere? This is something I'd really, really, REALLY like to do on my new C109RT... Name:  eusa_drool.gif
    Bought on 06/18/2016 for $6,500, with 1,864 original miles on the odometer (and I'm the third owner! Da fuq were the first two thinking?)
    Very Active Member 1r's Avatar
    May 2011
    cincinnati ohio
    sorry ive been away for a bit . aside from getting an m109 tach you will want to get the baron tach adapter for the c109 it easy and straight forward . the only other thing will be some sort of means to attach the tach to the bike . in my case its a kyuraklyn bar clamp using a threaded bolt.
    if you do a you tube search you will probaly find where some one posted a vid of his
    https://www.youtube.com/watch?v=ye7sgsVIpkA
    2008 c109rt . wolo air horn, gman tre, gman bully ,kuryakyn cruiser pegs, tsukayu jumbo strong bags ,tsukayu 6x9 bat wing , LED head light, driver backrest, k&n air filters, m109 tach, and electric cruise control ahhh !
    Active Member
    Jun 2016
    Tampa Bay, FL
    Yeah, I came across that video already. Unfortunately this is just too complicated a project for me to undertake right now. Hell, I still can't figure out how to install the SpeedoHealer.
    Active Member
    Oct 2015
    Australia
    I am thinking about doing this as well. I was looking at wiring diagrams a few weeks ago and it looks like it can be done without a tacho adaptor .Has anyone tried tapping into the factory sensor for the tacho signal or do I have to be the first.
    May 2011
    cincinnati ohio
    I do NOT have the adapter ! mine is wired into the coils with resisters and diods n stuff . with the ground and back lighting coming from existing wires in the bucket just as the you tube vidio puts it .
    The 30 bucks for the baron adapter is (IMHO) the way to go .
    I have been toying with the idea to move my turn signal indicators up to the tach and also my as7 indicator . and some of indicator lights for my cruise control . it would be nice to have those up and visible in front of me . The cruise unit is a tad hard to see during the day and it does not help that my phone holder and gps cradle partaily block the view of it . on my handle bars I have the tach ( centered ) on the left side I have the bully control , phone holder and the gps cradle . on the right side I have my cup/bottle holder . While it may seem odd to have both a phone and gps its due to the gps gets only used on longer and pre routed trips .
    baron part number BA-7315-50
    Active Member
    Oct 2015
    Australia
    I was looking at wiring it up the same as the m109. I read something about the baron adaptor not working properly at low rpm.
    May 2011
    cincinnati ohio
    I have a small "bounce " on the read out at idol .. reads out well beyond that and I don't have the adapter. It is in no way shape or form so bad that I have even looked into doing anything about it . It seems strange to me that the bike not only did not come with a tachometer but it was not even an option .
