Pop or back fire
Results 1 to 16 of 16
Thread: Pop or back fire
    Very Active Member T-peezie 109's Avatar
    May 2013
    olive branch , ms
    Default Pop or back fire
    Ok guys lately when I shift into second gear I get a loud pop or back fire sound. Any idea Whats causing this, and should I be concerned.
    Keep Your Kneez in The Breez
    Very Active Member DeafM109R's Avatar
    Apr 2012
    Kyle, Texas
    Quote Originally Posted by T-peezie 109 View Post
    Have you done anything to your bike such as modifications? Need more details. Could be too lean gas.
    If you want to be happy for a day, Drink.
    If you want to be happy for a year, Marry.
    If you want to be happy for a lifetime, Ride a Motorcycle.
    Jul 2008
    Forney, TX
    What intake, exhaust, and fuel management? Have you blocked the pair valve?
    Apr 2014
    Chesterfield, VA
    Have you had your exhaust off for any reason recently? Could be an exhaust leak.
    May 2013
    olive branch , ms
    Debaffle stock exhaust, xtre,
    Sorry but i dont know what a pair vavle is. I dont think i blocked it . Every thing is stock
    No i have not had the exhaust off for any reason.
    Sorry it has taken a few days been a lil busy!
    Jul 2008
    Forney, TX
    Here is the link. It sort of explains it, and could help with your issues.
    https://www.m109riders.com/forums/showthread.php?t=96869
    Apr 2014
    Chesterfield, VA
    Thanks Dreamer! I missed his post somehow.
    Jul 2008
    Forney, TX
    I'm guessing since he gutted his exhaust and prob running k&n or aftermarket intake without fuel management. Blocking the pair valve would be the only option. But would highly recommend a fuel mgr.
    May 2013
    olive branch , ms
    No Dreamer i am still running stock air filter and intake. Its the plan for winter mods to get a power commander and have the guy from here reprogram my ecu( i think thats what it is called)
    Jul 2008
    Forney, TX
    Ok, if your still running stock airfilters. Then I think the pair valve mod should help you out. I couldnt tell from your avatar if you had aftermarket intakes. And its a cheap mod. Some buy the plates, others have used marbles.
    May 2013
    olive branch , ms
    Ok thanks
    Jul 2008
    Forney, TX
    Ok thanks
    I dont know the exact purpose of the lair valve, but blocking them off has helped several with decel pop. I'm betting that once you opened up the exhaust it might have certain times it runs a bit lean, decel pop. Hope it fixes the issue for you.
    May 2013
    olive branch , ms
    Feb 2012
    Taz has some real nice covers on his.
    RIDE ALL YOU CAN. LIFE IS SHORT.
  17. #15
    Jul 2008
    Forney, TX
    Quote Originally Posted by SKIDMARK View Post
    Here is the link with pic's to Taz's pair valve block off plates.
    https://www.m109riders.com/forums/sho...d.php?t=289529
  18. #16
    Feb 2012
    Seeeeeee. Bliiiiiiiing. Very nice.
