Dreading motor mount replacement
Page 1 of 2 12 LastLast
Results 1 to 30 of 39
Thread: Dreading motor mount replacement
    Very Active Member waytootall67's Avatar
    Nov 2012
    Calgary Alberta Canada
    Default Dreading motor mount replacement
    Well boys and girls motor mounts are on the way so I thought I should prepare by looking for a how to posts for this monumental task(first time even removing the body panels ). It looks like the thread that Bobbymac did is very detailed but all the photos are missing. Is there some where else to get a step by step.
    Thanks in advance
    House of Chrome peg extensions, Full cut gel seat, CWI back rest,
    Cobra solo rack, Tsukayu hard bags, Gman TRE
    Factory installed GO FAST STRIPES
    Apr 2014
    Chesterfield, VA
    Quote Originally Posted by waytootall67 View Post
    Thanks in advance
    Wow! you must be an old fashioned take it slow kind of gentleman. I was up under mine's skirt within 2 weeks of knowing her!
    Here is Andy's (Some 9) video "how to" on changing the motor mounts.
    Nov 2012
    Thanks, ya little timid about stripping her down, everything up til now has been a bolt on. I saw Andy s video but he is kinda vague on a few things and Bobbymac how to looks a little bit more newbie friendly.
    Very Active Member GRUMPY's Avatar
    Feb 2012
    Denham Springs, Louisiana
    I must recently changed mine out following BobbyMac's how to. Andy's video is helpful too. It's not as bad as it seems. I did it by myself but having someone to help would make the job a lot easier. You definitely need a bike jack and a regular floor jack to support the motor!
    BOTM - January 2016
    2011 M109R LE....Not quite stock!
    I'm only GRUMPY when I'm not riding 1SICK9!
    Nov 2012
    Is the bike jack just to hold it upright? Was thinking of using my shop wheel chock to hold her steady and floor jack for under engine.
    Sep 2012
    Long Island, NY
    Bike stays on the kick stand, I've done it without a jack.
    Apr 2008
    mass
    I did mine with bike held with wheel chock and jack under motor.I did mine it's not that bad, if you were close I would help you do it.
    Feb 2012
    That will work just as well!
    BOTM - January 2016
    Jan 2009
    Nitra, Slovakia
    Quote Originally Posted by some 9 View Post
    I did it on the kickstand as well, with a little help of a small jack under the engine to align the holes when putting it all back...
    Aug 2010
    Mass
    Very easy did mine on the kickstand with help from a floor jack.
    Very Active Member Andy33's Avatar
    Jan 2010
    Calgary, Alberta
    Thanks in advance
    Nice! The bike is a lot smoother after doing them. Certainly use the Bobbymac thread. I found it to be the most useful.
    Give me a few days notice when you get the mounts. I can always whip over and lend a hand. I found (as did Bob) an extra set of hands makes this job a lot easier. Took about 2hrs start to finish. (on the kick stand with a floor jack)
    2009 M109 LE
    ISO grips, Swing Wing pegs, Shifter/Brake pedal MOD, Rivco 2" Risers, V-Stream Windshield, Cobra Sissy Bar/Rack, Tach Relocated, Mini Bullet Signals, Scythe 2 Mirrors, Debadged, DeBeaved,
    RaceTech fork Springs, Progressive 465, LA Choppers 2" bones, Cycle House Kickstand, Chrome Stock Wheels, Freedom Exhaust, Goldwing Intake MOD + K&N filters, Cobra Power Pro
    Aug 2007
    Montreal subburb
    If anyone can tell me how to post a pdf file ,
    I have the europeen site " how-to "on engine mounts
    it has all the pictures that Waytootall67 is looking for.
    or maybe , if you trust me ,
    send me a private message , with your e-mail adress in it ,
    and I know I can add a PDF file to a e-mail.
    Every Time You Lift Your Tank Beware Of This .
    Very Active Member hogeaterM109R's Avatar
    Oct 2014
    Indiana
    Did mine Saturday. One the side stand. Didn't remove the exhaust. Must have an extra set of hands for this method. I undid the zip tie on the frame rail and removed the bolt that hold the retainer for the flexible part for the rear brake line and dropped the frame down. It was a pain. I went in blind. If I had to do it all over again. I would put the shifter side of the removable frame section together first. Then get the other ones started before tightening them down. It wasn't bad in retrospect. It was intimidating at first as I was removing frame bolts and holding the engine up with a jack.
    Nov 2012
    Quote Originally Posted by Andy33 View Post
    Thanks buddy, you are my safety net if things go sideways. We still need to get together one of these days to do the rubber for beer swap.
  17. #15
    Aug 2007
    Montreal subburb
    PM replied to Waytootall67 and Tazdvl
  18. #16
    Sep 2012
    Long Island, NY
    Quote Originally Posted by Kazimodo View Post
    You can add it to your drop box if you have one and then just add the link here.
  19. #17
    Aug 2007
    Montreal subburb
    I don't know what a " drop box " is , so I guess I don't have one
  20. #18
    Dec 2007
    Toronto, Ontario, Canada
    My understanding is that the top mounts are usually the ones that really need replacement, while the bottom one is usually not as worn. I plan on doing just the tops this summer.
  21. #19
    Very Active Member DutchM1800R2's Avatar
    May 2014
    Netherlands
    The front ones are usually the most worn. They are originally the softer ones. The top and bottom rear are made of a harder rubber. The top ones are easily replaced, the bottom ones can only be done when removing the engine.
  22. #20
    Jan 2009
    Nitra, Slovakia
    Default motor mounts
    Quote Originally Posted by DutchM1800R2 View Post
    Only the rear top ones are harder,
    front ones and rear bottom ones are softer.
  23. #21
    May 2014
    Netherlands
    Absolutely right, I stand corrected!
  24. #22
    Nov 2012
    Well guys I did it thanks to all the info on this site. Hardest part was putting my cobra case guards back on.
    I do notice a tad vibration at low rpm but where as before 120km on the highway was a paint shaker now has become the sweet spot, smooth as butter.
    Thanks again
  25. #23
    Jan 2010
    Calgary, Alberta
    Good to hear you got it done!!
    It seems like a scary task until you jump in. I found it smoothed things out at higher speeds too.
    2009 M109 LE
  26. #24
    Nov 2017
    US
    Thanks to you guys once again on the various repairs.....in particular this motor mount replacement.
    Sent from my SM-N960U using Tapatalk
  27. #25
    Apr 2014
    Chesterfield, VA
    Wow! A blast from the past on this thread. Several names In this thread I haven’t see in a few years!
  28. #26
    Aug 2007
    Montreal subburb
    While talking about older members ,
    Does member '' Scorp '' still sell harder mounts , with different technology rubber?
  29. #27
    Jan 2010
    Calgary, Alberta
    If I'm not mistaken these are what you're looking for.
    http://secure.billydump.com/store/in...&productId=287
    2009 M109 LE
  30. #28
    Aug 2007
    Montreal subburb
    Thanks a lot Andy33 ,
    Tried to buy a set , no way to calculate shipping on site ....'' shipping to be added ''
    not going to buy blindly without knowing shipping costs , too bad ..
    sent them a email to get ball park figure shipping cost , might still buy from threm
    less than 15 minutes later , already got an answer = $21 US shipping for 1 or 2 sets .
    guy who replied to me is an old member here , I remember him and his funny posts ,
    and he was very knowledgeable , too bad he left the site ....big loss fr all of us ===> TRod .
  31. #29
    Apr 2014
    Chesterfield, VA
    that is Tracy’s (Trod) website. I haven’t seen him on here in forever tho.
  32. #30
    Aug 2007
    Montreal subburb
    he said : '' . I left the site some time back because of comments by another member ''
    I missed that , I don't come here as much as before , my moto trip to Arizona and Utah ruined biking
    for me in my neighborhood , so little to see here , in the 5 months of riding available.
    i sure had TRod ( Tracy ) as ''thick skinned'', wonder who hurt him ?
