Iridium plugs
Results 1 to 16 of 16
Thread: Iridium plugs
    Very Active Member Jersey9's Avatar
    Nov 2014
    North New jersey
    Default Iridium plugs
    Ordered some NGK iridiums. Question is do you guys check for gapping on these plugs, don't want to damage the center iridium piece.
    Sep 2010
    McPherson, KS
    Yes. Better to check and adjust than trust that they were pre-gapped properly for your application.
    Very Active Member BAD BOY M109R's Avatar
    Harwood Mo. (SW)
    agree.....
    BONE STOCK
    Very Active Member BAMF109R's Avatar
    Mar 2016
    Indianapolis, IN
    Quote Originally Posted by Jersey9 View Post
    Absolutely check them, because they are more than likely NOT correct or even the same from plug to plug. Just a note when adjusting the gap on iridium plugs, there is a special tool to do so, don't use the old turn dial type adjuster or you will damage the electrode in the plug.
    Sep 2010
    McPherson, KS
    Quote Originally Posted by BAMF109R View Post
    You can use the turn dial type tool. There is a hole in the tool for bending the side electrode, you don't actually use the thickness measuring edge to open up the gap, you just use that edge to measure the gap.
    Nov 2014
    North New jersey
    Good info using the center hole, thanks.
    Very Active Member DutchM1800R2's Avatar
    May 2014
    Netherlands
    To get back onto topic..
    I've just ordered two sets of these (both for me and a friend). Never messed with plugs before, what tools would you guys recommend to check the gapping and what tool to adjust it if needed. Preferably with an eBay or Amazon link.. that would help!
    Cheers!
    Nov 2014
    North New jersey
    Quote Originally Posted by DutchM1800R2 View Post
    Cheers!
    I bought a feeler gauge on eBay. Checked the gap and they all seem within spec.
    Jan 2009
    Fergus, Ontario, Canada
    Cheers!
    Any local automotive store will have them. There is several styles , here is one example..:
    http://www.ebay.com/itm/K-D-Tools-32...pWBVDP&vxp=mtr
    Super Moderator BoardMod's Avatar
    Feb 2010
    Thread cleaned
    Active Member
    Oct 2015
    Australia
    Have they fixed issues where the tips went missing.
    Very Active Member Dragonback's Avatar
    Feb 2008
    Staten Island, New York
    Gap? whats the correct setting for the IRIDIUM
    BTW... I got the 9exi as they were mentioned to run colder?
    any input on this?
    Jan 2009
    Quote Originally Posted by Dragonback View Post
    any input on this?
    See if you are talking about this one, and then click on "Specs":
    http://www.ngk.com/product.aspx?zpid=9688
    Feb 2008
    You da man...
  17. #15
    Feb 2009
    Oklahoma City
    Quote Originally Posted by C109rt_aus View Post
    Exactly! The one and only time I used iridium plugs, the center electrodes were gone in 5,000 miles. I'm talking all six cylinders, on a vehicle with no known issues, check engine light off, no PD codes. Vehicle still ran, amazingly. So I'll not ever use them again. I'll just stick to platinum plugs. Never ever had a platinum plug lose the center electrodes.
    They were NGK's, btw.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
  18. #16
    Active Member
    Oct 2015
    Australia
    That's why I asked a mate of mine worked at an auto parts store and when they first came out he fitted them only to find the tips missing at the next service.
    Just curious to see if the issue has been fixed or not.
