Converting the stock sissy bar and luggage rack to a detachable one
Page 1 of 3 123 LastLast
Results 1 to 30 of 61
Thread: Converting the stock sissy bar and luggage rack to a detachable one
    Very Active Member flcusat's Avatar
    Apr 2013
    Miami/FL
    Default Converting the stock sissy bar and luggage rack to a detachable one
    OK guys, the chrome on my stock sissy bar and luggage rack is in bad shape.
    I can send it to chrome for about $250 and I was thinking that before doing that, I could try to make it a detachable one and send it to chrome.
    Has anyone done that before?
    2007 M109R, Mods: Avon Air Grips, Custom Derby Cover, Rivco Brake Pedal, TRE.
    Jan 2009
    Fergus, Ontario, Canada
    Quote Originally Posted by flcusat View Post
    I am about to do that . IMO you need to notch the mounting holes to "U" shape obviously, and then depends on what locking system you buy, drill the holes for it. I bought HD hardware , but it is still in the bag. 'Some9' gave me that idea....
    HD hardware:
    .For the cut outs check the pictures of Jardine here:
    http://www.cruisercustomizing.com/ja...art/34-4007-01
    . I found some parts here:
    http://www.ebay.ca/itm/DETACHABLE-SI...mtr&rmvSB=true
    http://www.cavalrycustoms.com/store/product173.html
    http://www.cavalrycustoms.com/store/product368.html
    Obviously you need to buy proper metric bolts....
    Apr 2013
    Miami/FL
    Thank You for sharing. I will look into that.
    Apr 2013
    Miami/FL
    HD hardware:
    Is there a particular reason why you selected this kit? I know they make different ones for models and years.
    Apr 2013
    Miami/FL
    Also, how the chrome looks on those latches. I rather spend a little bit more in the real one from HD than in a knock off that eventually it is going to peal.
    Jan 2009
    When I was shopping for it, I found only this one suitable. My latches are black because Cavalry did not have any in stock, so I ordered those EBay ones - only available in black at that time...
    Nov 2008
    Newmarket, Ontario
    Someone just had a Jardine removable backrest in the forsale section...
    Very Active Member lmbull's Avatar
    Apr 2012
    Ohio
    I did the same thing with the HD hardware. https://www.m109riders.com/forums/sho...d.php?t=237186
    Sent from my SM-G900V using Tapatalk
    Apr 2012
    Ohio
    I apologize. I had planned on giving more details about how I did the mod and got side tracked. After I get home tonight I'll post some close ups. I drilled the existing holes out slightly larger than the diameter of the nylon on the mounting post then cut the slot with a band saw and filed it . I used masking tape to protect the chrome and it makes it easy to lay out the lines. The exact position of the mounting bolt the latch pivots on was a little tricky to figure out. The third picture shows how I lined up the latch to the slot to transfer the hole location.The chrome doesnt look as bad as it does in these pics.
    Apr 2012
    Ohio
    Apr 2012
    Ohio
    Apr 2012
    Ohio
    Apr 2013
    Miami/FL
    Thank you for sharing this. I don't know how come I had missed the thread that you posted.
    How is the finish on those latches? I rather paid the extra $30 for the originals for a better looking finish
    Apr 2013
    Miami/FL
    Well, after reading the whole thread it looks like I made some comments there and I don't even remember it, isn't that great.
    Could you please some close up of the bags and how they attach?
    Thanks in advance.
  17. #15
    Apr 2013
    Miami/FL
    After further analyzing the pictures also realized that the latches are going on the inside part, so the finish it might not be that important.
  18. #16
    Apr 2012
    Ohio
    The finish is nice. Don't get to hung up on it though. You hardly see them.
  19. #17
    Apr 2012
    Ohio
    I'll get some pics of the bag mounting later tonight.
  20. #18
    Apr 2013
    Miami/FL
    Quote Originally Posted by lmbull View Post
  21. #19
    Apr 2013
    Miami/FL
    From this kit:
    Do you use only the posts or the spacers are also needed?
  22. #20
    Apr 2012
    Ohio
    From this kit:
    I didn't use the spacers. I used hardened washers and adjusted accordingly to get the right spacing for the width of the backrest.
  23. #21
    Apr 2013
    Miami/FL
    That is what I thought. Thanks.
  24. #22
    Apr 2012
    Ohio
    I used a countersunk flat head so the bolt wouldn't interfere with the latch.
  25. #23
    Apr 2012
    Ohio
    I cut the bolt so that it didn't stick out of past the lock nut.
  26. #24
    Apr 2013
    Miami/FL
    Thnaks, but what modification did you so to the top part of the brackets since they were supposed to land where the post are.
  27. #25
    Apr 2013
    Miami/FL
    Never mind, I just realized hat you just moved the whole bracket a little bit to the side.
  28. #26
    Apr 2013
    Miami/FL
    The post that you used looks like these?
    These look like original HD posts. Or the one the Calvary Home sales?
    The reason I'm asking is because I have free time to do this this weekend and I can get the original ones from a local HD dealer.
    I looked to every single one on HD web site and pretty much all of the post look identical to this, but the wider post that Calvary sales looks different (a little bit wider on one of the chrome side).
  29. #27
    Apr 2012
    Ohio
  30. #28
    Apr 2012
    Ohio
  31. #29
    Apr 2012
    Ohio
    The short post looks the same as the HD one but the long one will need about a half inch spacer.
  32. #30
    Apr 2013
    Miami/FL
    Yes, this is what I noticed. I went through the whole HD collection and none of them is like the one on Calvary's.
