M 90 headlight
Results 1 to 17 of 17
Thread: M 90 headlight
    Very Active Member leadsled's Avatar
    Dec 2015
    British Columbia
    Default M 90 headlight
    I am not impressed with the brightness of my headlight. Does anyone have an easy fix for this. I do not want to get into rewiring or anything like that. If you have a link to a brighter bulb switch over it would be greatly appreciated.
    Member ChromeThunder007's Avatar
    Jun 2014
    TEXAS
    Here goes my two cents.... At my first attempt to upgrade my headlight bulb I bought an H4 Philips X-Treme Vision bulb. Like you, I wanted to avoid cutting/splicing, basically anything that would make me modify my virgin OEM wiring. I currently live in Europe and the laws are very strict. IF I would have gone with an HID or high power LED, I will most-likely fail the annual safety inspections.
    So I am here to recommend to you NOT to buy an Xtreme Vision bulb. I went from a 6 year old OEM General Electrics H4 bulb to the Philips and my results are "Xtreme"-ly disappointing. I can barely notice the difference while riding at night. The high beams are slightly better than stock. I only paid €12 euro at the store for one. Look at the pics below and see for yourself what I am talking about. Top is before and bottom after.
ID:	305818Click image for larger version.
ID:	305826Click image for larger version.
    Mar 2009
    Sunshine Coast, BC, Canada
    I installed a PIAA Bulb and what a difference. Here is the info if you want to have a look
    http://www.piaa.com/store/p/159-H4-X...ogen-Bulb.aspx
    Be careful what you shoot at. Most things in here don't react too well to bullets. - Capt Ramius (Red October)
    2006 DL650 Blue
    2009 VZ1500 M90 Blue
    Very Active Member amvince's Avatar
    Jun 2009
    Frisco, TX
    YOu can also try Sylvania Silverstar line.
    I just plan on doing everything twice when I start it and that way when it takes 3 times to get it right I'm only half as mad.
    Jun 2009
    Frisco, TX
    Just saw this on the 109 side. Might be the best choice.
    https://www.m109riders.com/forums/sho...d.php?t=296521
    Active Member
    Feb 2016
    CT
    I ordered hid kit came in yesterday but with wrong order the ballast are no bigger then roll of quarters. Once I get proper parts and install I'll let you know.
    Dec 2015
    British Columbia
    as per " some 9 " on the 109 threads :
    Just purchased a set of theses led headlights and I got to tell ya I'm very impress with it, plus its such an easy install. Will be getting these from now on. I ordered the H4 LED's off ebay and will post up my thoughts once installed.
    Active Member
    Feb 2016
    CT
    I overnighted LEDs for Hahas last night too. I'll be installing tonight if snow holds off I'll put her on street and post pics. I ordered yitamotor h4 as they had a high verified purchase rating on Amazon
    Active Member
    Jul 2015
    South Elgin Il
    Where are you guy's buying these LED lights from? Thanks for the info!
    Dec 2015
    British Columbia
    go here and click on the link. This is where I ordered mine from: https://www.m109riders.com/forums/sho...d.php?t=296521
    Active Member
    Feb 2016
    CT
    Light is borderline acceptable. I need a dark road to really get a feel for them without other light pollution. Color is great though
    Mar 2015
    ontario, canada
    Any feedback on these LED's in a 90?
    Active Member
    Jul 2015
    South Elgin Il
    I bought my LED on E-Bay MOTOLED 12v 20w H4.. Nice.. Plug in like a regular bulb
    Active Member
    Mar 2014
    Orlando
    Quote Originally Posted by NoLimitzR1 View Post
    Is it plug and play?
  17. #15
    Active Member
    Mar 2014
    Orlando
    Quote Originally Posted by fstkat View Post
    Did you notice a big difference?
  18. #16
    Active Member
    Jul 2015
    South Elgin Il
    oh yes I get flashed sometimes on low beam. When I hit the highs they get it. lol
  19. #17
    Active Member
    Feb 2016
    CT
    Quote Originally Posted by mike226 View Post
    They matched my 6k hid in color and cutoff. Led build kept coming loose due to a check ball that indexes the bulb due to using my dust cover. Hid fits snug. I used mount less ballast opt7 bullets
