Upgrade your Clutch System - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 31 to 60 of 68
Thread: Upgrade your Clutch System
  1. #31
    Very Active Member mlrman's Avatar
    May 2011
    central IL
    Sounds good, thanks man.
  3. #32
    Jul 2008
    Forney, TX
    Quote Originally Posted by mlrman View Post
    Can anyone explain why there are alternate clutch drive plates to #6? (7,8 in diagram?) Thanks.
    Quote Originally Posted by edwilk55 View Post
    It was asked / answered in a separate post I found when researching. The word was just stick with 6 (std part # when ordering), but I can't recall why.
    Sent from my Apple brain boiler...tapped by the NSA, hacked by the FBI!
    It has to do with the thickness of the stack up. Your suppose to get the measurement and based on that measurement, go with the proper drive plate #6, #7, or #8. I stayed with #6 when I changed my clutch out and havent had any issues.
  4. #33
    Very Active Member rookiepg's Avatar
    Jul 2009
    Prince George, BC. Canada
    Clutch is in. Fits perfectly.
    Initial impressions with the 8 miles I was able to ride is it's great. Clutch pull is easier. 1-2 shifts aren't as notchy.
    I'll give another update after I put some miles on this coming Sunday.
    Havent seen any updates so I thought I'd give ya a nudge. :)
    I assume you've put on many more miles than above. What do you think of the upgrade? What are the differences you've noticed from before. Anything you're still not completely satisfied with?
    Thanks for the info.
    Still chilled in BC, Canada.
    Paul
    SIGPIC]
    2008 Black M109R
    MODS Begin: Speedometer Face Plate, Amsoil Full synthetic, C.W. back rest, 2'' chrome risers, Spear Air Intakes, Dunlop Elite III 250, LeatherLyke Saddlebags
  6. #34
    Very Active Member edwilk55's Avatar
    Apr 2011
    Jonesboro, GA
    Quote Originally Posted by rookiepg View Post
    Paul
    So far, so good. It's an exact fit, just a better design.
    Smoother clutch pull and, from what I've read, stronger grab.
    I highly recommend of you're going to do the clutch anyway. It's a win win.
  7. #35
    Jul 2009
    1st to 2nd issues? And the reverse, (downshifting)
    sounds like you're only recommending this upgrade IF the bike is in immediate need of it.
    Cheers
    SIGPIC]
    2008 Black M109R
  8. #36
    Apr 2011
    Jonesboro, GA
    Cheers
    1st to 2nd is more precise. I don't recall the last time I had a missed shift or the clunk.
    It's pricy, so yeah, don't think I'd say it's worth the spend over stock. My humble .02.
  9. #37
    Jul 2009
    I always appreciate a members 0.02$ ESPECIALLY if they have personal experience with the matter. So thank you for that. :)
    Once it was all said and done, what was your finally cost?
    Cheers
    SIGPIC]
    2008 Black M109R
  10. #38
    May 2011
    central IL
    Cheers
    another member shared this with me before I did the mod last year:
ID:	344250   Click image for larger version.
  11. #39
    Jul 2016
    Delaware
    Default Bike moves when I put it in gear after the upgrade
    Hello Guys, I just completed the 2007 to 2011 clutch upgrade. My clutch was slipping in second gear around 4000. I changed out the complete clutch pack. Now when I put the bike in gear it starts to move. I noticed that the new clutch pack was taller than the old one. Has anyone else experienced this?
  12. #40
    Apr 2011
    Jonesboro, GA
    Quote Originally Posted by bim28 View Post
    I know it all fit back in w/out issue and had been working gr8 since installation last year.
  13. #41
    Jan 2009
    Fergus, Ontario, Canada
    Did you adjust first the push pin and then both ends of the clutch cable according the 'Shop Manual'?
    PS.
    I hope you also changed the springs as posted by Rainey.
  14. #42
    Jul 2016
    Delaware
    PS.
    I left about a 1/4" of play for the push pin. I adjusted the clutch lever. I didn't change the springs. I still have the stock springs.
  15. #43
    Apr 2011
    Jonesboro, GA
    You need the springs that go with it if I remember correctly. I know I changed those as well.
  16. #44
    Jul 2008
    Forney, TX
    The free play at the lower end of the cable isnt enough. Had this same issue then I replaced mine.
    You need to adjust the lower arm before you adjust at the lever. By not having enough free play at the bottom even is you have enough at the lever its not letting the clutch fully disengage.
    How I check mine is when I have the clutch pulled in i let my heels just keep the bike up and see if the bike moves. I do this in the garage on a flat and level surface.
  17. #45
    Jan 2009
    I have not done this myself, but will be soon . In the Suzuki Service Manual it is described like this:
    • Loosen the lock nut and screw in the release screw to feel resistance.
    • From that position, turn out the release screw 1 full turn and tighten the lock nut securely by holding the release screw.
    If you don't have 'Service Manual' download it here:
    http://www.mediafire.com/file/m2zniy...ice+manual.pdf
    You can double check the procedure on page 163, (paragraph 3-111)
    PS.
    One needs to replace the old guts with "ALL" these new ones:
    https://www.m109riders.com/forums/sho...=1#post3737250
    and the 'Push Pin' adjustment is here:
    post img
  18. #46
    Jul 2016
    Delaware
    Thanks Guys, I appreciate all the feedback. I will pull it apart this weekend.
  19. #47
    Jul 2008
    Forney, TX
    PS.
    post img
    Do you have an updated link for the manual? The one you listed gives me an error. Im try to download a copy to my new cell.
  20. #48
    Jan 2009
    It does work with my desktop, I just double checked it.
  21. #49
    Jan 2009
    Default 2011-up clutch hub quieter
  22. #50
    Very Active Member kshackelford's Avatar
    Jan 2017
    Ky
    Have 06 m109R. Clutch not right hard to shift 1-3 especially when motor gets warm. I can be driving at around 50 pull clutch in and rev bike and bike will shutter real bad. Sitting at stop ligght pull in clutch and rev up and the bike will try to take off and feels like something jerks real hard horrible sound. Bought a new clutch cable been adjusted twice. So I am going to try to upgrade to the 2011 clutch and make hydraulic.
  23. #51
    Member KL9's Avatar
    Jul 2011
    Aldan, PA
    It's was in any gear and yes, it fixed it, buuuuuut... I didn't need the upgrade to fix the slipping. I found I installed the inner plate 10 backwards when I did the pin mod last year, so while it worked for a season, it ate up two plates causing my slipping.
    I know this is an old post for you, but I have a question about the clutch slipping issues. I had my clutch replaced by a dealer at around 22k and since that time my bike will not go any faster than 100 mph and I'm in 5th gear on the highway. Is this an example of the clutch slipping? I have taken it back a couple of times only to be told, they can't find any problem yet there is one, because the bike should not tap out at 100mph.
  24. #52
    Jul 2008
    Forney, TX
    Quote Originally Posted by KL9 View Post
    Are the rpms still climbing but not the speed?
  25. #53
    Apr 2017
    St. Louis Missouri
    PS.
    post img
    Thevili.....that is only for when you change out your clutch plates right?
  26. #54
    Jul 2008
    Forney, TX
    Quote Originally Posted by sssportsmfg View Post
    I would recommemd it anytime you have the clutch cover off. You are basically readjusting the clutch from scratch. Adjust push pin, then lower section of clutch cable then at the lever.
  27. #55
    Jan 2009
    Just like 'M109Dreamer' said. In any way, one takes off the clutch cover
    usually for a reason, like clutch is NFG - Not Functioning Good, therefore
    IMHO proper adjustment from push pin and up is necessary before one
    proceeds in further troubleshooting.
  28. #56
    Oct 2010
    Germantown, MD
    Did this to Bikergranny's last year. 7k miles of the best clutch setup she has ever had. She has Rhumatoid Arthritis and she has been having hand issues with the older setup. Since changing she has simply loved it and I wish I had done it earlier for her.
  29. #57
    Jan 2017
    Ky
    I have a question about my m109r. I installed a Revo clutch. Did the push pin mod. But the bike is starting to pull with the clutch in again. Is it worth upgrading to hydraulic clutch.
  30. #58
    Jan 2009
    Quote Originally Posted by kshackelford View Post
    IMHO your problem is n clutch adjustment,
    starting with the push pin, and then the cable.
  31. #59
    Jan 2017
    Ky
    At first was great, longer I rode worse it got again
    Sent from my SM-G955U using Tapatalk
  32. #60
    Jul 2008
    Forney, TX
    If you know you adjusted the push pin then look at the free play at the bottom of the clutch cable arm. If there isnt enough slack at the bottom the clutch will remain engaged.
    When I did my clutch had the same prob.
    Disconnect the cable at the lever and adjust the slack according to the book. Then hook the cable at the lever and adjust for the slack there.
