Bad Rectifer taking out a Stater?
Results 1 to 19 of 19
Thread: Bad Rectifer taking out a Stater?
    May 2014
    McQueeney, Tx
    Default Bad Rectifer taking out a Stater?
    Is it possible for a defective rectifier to kill a stater?
    Very Active Member 1r's Avatar
    May 2011
    cincinnati ohio
    Yes it could , but as to how likely that's hard to say .
    2008 c109rt . wolo air horn, gman tre, gman bully ,kuryakyn cruiser pegs, tsukayu jumbo strong bags ,tsukayu 6x9 bat wing , LED head light, driver backrest, k&n air filters, m109 tach, and electric cruise control ahhh !
    Nitra, Slovakia
    Bad rectifier damages your battery, repeated attempts to start the engine with "low battery" is hard on the starter, but IMHO will not "take out" the good starter...
    May 2014
    McQueeney, Tx
    Not starter..... Stater ---- the generator...
    Nitra, Slovakia
    Quote Originally Posted by BradS View Post
    My bad, I read "starter" but you wrote "stater" and meant "stator" - ...
    Very Active Member TheFNG's Avatar
    Sep 2014
    Cape Cod MA
    Heres some info I found on the subject.
    Rect Diodes can only fail one of 2 ways
    Open or Closed
    Open is a road to nowhere,,,same as if you'd cut the stator wires.
    How many "Dirt Bikes" ya think there are in the world,,,Stripped of EVERYTHING possible,,,,,,while the generator whirls away?
    Gazillions run like that for Years and Years.
    Then somebody Reconnects the Lights,,,and Voila!,,they work fine.
    Which proves that a Failed Open Rectifier is harmless to a stator.
    A Failed Closed Rectifier Diode,,,it dont care either
    It spends half it's life Blocking current,,,and Other half Passing current.
    Passing current is a LOT less load than Blocking it.
    A failed Rect Diode behaves like merely an extension of the output wire from the Stator.
    No Longer a Semi-Conductor,,,it becomes a Full Conductor
    Stator dont care if it's wires are 16" long or 16.01".
    The trouble is a Closed Diode passes Both sides of the AC wave
    Stator OutPut goes Thru Rectifier then Straight to the Battery
    If Rectifier is Not Rectifyin' the AC into DC,,,,
    WHICH type of Current is the Battery Getting?
    Yeah,,,AC.
    What does AC do to the battery?
    Ever Crosswire Jumper Cables?
    Connect Positive directly To Ground?
    Grand Mal SHORT.
    That's as Short Circuit as ya can get
    AC Into a Battery,,,gets Shorted at BOTH Poles on an alternating Basis,,,every cycle swing
    Positive Pole gets hit with Negative Polarity
    and an instant later
    Negative Pole gets hit with Positive Polarity
    Does that several dozen times per second.
    Like a Tug-o-war of electrons trying to charge the Batt.
    It'll eventually Kill any battery.I dont mean Drain it as in "dead Battery"
    I mean KILL as in Mortally Wounded.
    Obvious question is Why not Immediately?
    How can a Batt take that abuse for Days before Dying?
    That's complicated.
    Simple version includes 2 main principles.
    #1 is because a Batt is Constructed to produce a certain polarity and will persist in that function untill it's electrolytic capability is destroyed.
    #2 is odd,,,,but even with AC input the Batt is getting SOME small semblance of a charge
    At the batts Positive Pole,,it get a Half of the AC wave cycle in proper phase,,,before it Reverses into Negative polarity
    So it DOES get a Pulse of Positive Current at the Positive terminal
    It Also get a Pulse of Negative Charge at the Negative terminal,,,before IT reverses to Opposite Polarity
    And for a very brief instant,,,,On the AC Sine wave,,between the Peak + and Trough -,,,
    there exists a Baseline of ZERO Polarity.
    And for that brief instant,,,there's No countermanding polarity to oppose what's going into the battery at the moment on a particular terminal.
    Gets even more complex with 3phase generator,,,and multi poles.
    That's about the point where It's over my head and I quit,,,and leave it to the engineers & take there word for it.
    (Meaning Lots of Smile & Nod & pretending I have even a faint Idea what they just said)
    Anyway,,,NO a Rectifier cannot really damage a Stator
    And Yes,,a Battery can SEEM fine,,,and within a Few days not only be drained but Destroyed.
    Simple answer is,,,Replace your Rectifier.
    You can test Stator Output according to Repair Manual if you want to.
    Battery,,,,,odds are it needs to be replaced also.
    You can TRY Charging it--never hurts to Try.
    And plenty enough ARE saveable to suggest Charging is worth a try and not totally impossible
    Hope any of that gibberish makes any sense
    The Theory of everything involved fills entire sections of Libraries.
    The Practical application,,,and testing and trouble shooting would fill a small book.
    Then when it comes down to What Ya can Do about it,,,you can write it all on a business card.
    Test Stator,,,repair or replace if necessary
    Test Regulator/rectifier,,,replace if Necessary
    Test Battery,,replace if necessary
    09' C109RT Thunder Teardrop Intakes;Cobra PowrPro;GIpro TRE/gear indicator;cobra exhaust;Tsukayu 7" Stereo/GPS Boox One Fairing;Tsukayu Jumbo Strong bags;fender chrome; Rear Master cylinder Chrome;Tank bib;headlight visor,driving light visors,speedo visor and directional visors;Throttle lock; Kuryakyn cup holder;Kuryakyn mirrors;Kuryakyn Dually ISO Highway pegs;TMS Trunk; zXe head light and driving light bulbs;Draggers;Denali air horn
    A bad regulator/rectifier might damage a stator. The rectifier, besides rectifying the AC from the stator into DC for the system, also shorts some of the output to ground (usually through SCRs but some newer models use MOFSETs) to control the output voltage. In a permanent mag system, the stator outputs all it can all them time. The output is based generally on the RPM of the rotor. The faster the rotor is turning the more the system produces.
    If the regulator is shorting more to ground than it should (system voltage would probably be down) then the stator would likely see a lower than ordinary resistance to ground which might cause it to run hotter than it should and at some point could cause the premature breakdown of insulation on the windings (just a thin shellac) and cause them to short together lowering output.
    May 2014
    McQueeney, Tx
    Quote Originally Posted by thevili View Post
    well **** I was on my phone and googled some info and stater was the spelling when I put stator LOL---- guess google was wrong and I wasnt for once LOL
    May 2014
    McQueeney, Tx
    Well I finally found out my issue.... The stator is putting out way to much.... idle is 35.... about 3k is 120 and around 6k its putting out 240.... Manual said 70 at 5k rpm.... Looks like I will be pulling the this weekend
    May 2011
    cincinnati ohio
    Do you have a tach on the bike , to confirm the speed to charge ratio ? Originally I mis read part of this . Also are you sure you have the right setting on your meter ?
    I'm not sure it's possible for a stator to put out more than the book by very much. It might do maybe 20 or 30 volts more but not more than 3 times. I would suspect the meter or the meter setting. Make sure to use AC volts and check each of 3 pairs (1-2, 2-3, 1-3) unplugged from the regulator.
    Nitra, Slovakia
    Maybe this will help you:...
    May 2014
    McQueeney, Tx
    I used 3 meters because I didnt believe it myself.... I know how to test the stator... Even watched the video 3 times before testing it to make sure....
    Im going to test it one more time to make sure... and yes I know to use the AC setting on the meter
    Oct 2015
    Australia
    That's interesting 240 volt wow. What were the resistance measurements between the phases .
    May 2014
    McQueeney, Tx
    .4 between all 3 and OL to ground
    The ohms between phases probably won't tell you much. As long as you don't have any that are grounded then the stator isn't shorted to the core. Even though you could have some windings shorting to themselves, that would lower the voltage output, not raise it.
    The only way it could be putting out more than the book value is to increase the number of winds of wire on each stator post or to increase the magnetic field of the rotor. To get more than 3 times the rated voltage would require a LOT of extra winds of wire or a massive increase in the magnetic field. To get that much wire on the stator means to have to use much smaller wire. There's just not room to put additional wire on unless you drop the size. I can't imagine that your stator was wound with much more wire of a smaller size than every other 109 stator. And, it would have been that way from the factory. Doubtful.
    Not sure what the issue is at this point. I've tested and replaced a lot of stators and can say that they never put out more than 20-30 volts more than the book even when wound with some extra wire. As they age, the output drops as the windings short to themselves and sometimes to the core as the insulation breaks down due to heat.
    Very Active Member CruiserC109R's Avatar
    Pepperell, Massachusetts
    I just got a safety recall notice in the mail for the regulator/rectifier cover by Suzuki no cost to us
    2008 C109R Maroon 5,290 Miles, Cobra Speedster Longs Pipes, Power Commander III Dynojet, Chrome Fender Tips, Cobra Back Rest, Tank Bib, Cobra Fatty Bars, Chrome Caliper Covers, Chrome Drive Shaft Cover. Harbor Freight Motorcycle Lift!
    Member Poot's Avatar
    Mar 2015
    Buena Vista, Colorado
    Just got a RECALL NOTICE from Suzuki today in the mail on this very subject. They know I exist. They may not know that you exist. Here are the instructions:
    Go to suzukicycles.com
    Select SAFETY RECALLS at the lower right side of the home page.
    When the page refreshes, select RECALL NOTIFICATION LETTERS.
    Select RECTIFIER REIMBURSEMENT.
    Again, just got this in the mail today from Suzuki.
    Good luck.
    2008 C109R (purchased bone stock), TRE, Cobra fatty highway bars, Kuryakyn pegs
    C109RT OEM windshield and lowers purchased new as aftermarket on ebay
    Cobra Speedster Slashdown 3822 pipes, Servo-buddy (servo removed)
    Clutch pin mod and plates and wave washer fix
    Cobra PowrPro Black is junk
    May 2014
    McQueeney, Tx
    I know about the recall..... But my Stator is bad..... I have a new rectifier that I have not put on because I dont want to burn it up as well. Im going to call the dealer Tuesday and set up an appointment to have them replace the rectifier and see if they have an issue with the Stator as well.
