Which Type of License Plate Relocator Do You Prefer?
Page 1 of 2 12 LastLast
Results 1 to 30 of 47
Thread: Which Type of License Plate Relocator Do You Prefer?
    Very Active Member 5Twenty's Avatar
    Jul 2015
    Phoenix, AZ
    Default Which Type of License Plate Relocator Do You Prefer?
    I'm going to get a license relocator kit and I have an Idea of which type I like.
    Just wondering what the community thinks. Which of these 2 types of license relocator kit do you prefer? (please presume there is a horizontal option for the swing arm mounted type)
ID:	281474   Click image for larger version.
    Very Active Member Duende01's Avatar
    May 2009
    Clarksville, Tennessee
    The vertical mount is not legal in every state, so I would check the laws for your particular state for the laws there before spending the money.
    Sent from my SM-N910C using Tapatalk
    -2008 M109R "The Silver Bullet"
    -2013 HD Road King "The Orange Crush"
    -2015 HD Sportster Iron "TBD"
    Jul 2015
    Phoenix, AZ
    Quote Originally Posted by Duende01 View Post
    I live in Arizona. We can do anything here. But seriously, I checked to state laws. In this state, it boils down to: plate on the rear, securely attached and clearly visible. There is a part that says 12 inches off the ground that may be a sticking point.
    But let's assume there is a horizontal option.
    ARS 28-2354. License plates; attachment
    (L96, Ch. 76, sec. 7)
    A. A person shall display the license plate or plates as follows:
    1. For a motor vehicle, motorcycle, trailer or semitrailer, on the rear.
    2. For a vehicle for which two license plates are issued, the vehicle owner shall display either of the following:
    (a) One plate on the rear.
    (b) One plate on the front and one plate on the rear.
    B. A person shall display all license plates as required by subsection A until their lawful use expires or is canceled or revoked. A person shall maintain each license plate so it is clearly legible. A person shall securely fasten each license plate to the vehicle as follows:
    1. To prevent the plate from swinging.
    2. At a height of at least twelve inches from the ground to the bottom of the plate.
    3. In a position to be clearly visible.
    May 2009
    In that case you're good to choose whichever style you like. I like it under the fender, although my license plate is no longer that big. This was taken in Europe...
    Jul 2015
    Phoenix, AZ
    Yours looks really awesome I can see myself going exactly the way you did. Of course I don't base my choices on what others think. But I do like to know what others think.
    May 2009
    Quote Originally Posted by 5Twenty View Post
    Thanks!!! Mine was one of the last ones, if not the last one made by an old time member here with the screen name Sorge. Perhaps if you place a willing to buy or looking for announcement in the 4-Sale section you might be able to get one from someone who might have one just laying around or collecting dust on a shelf somewhere. Good luck in your search!
    Apr 2014
    Chesterfield, VA
    I like the "New Cycle House" bracket. It tucks the plate back farther and brings the turn signals in tighter.
    Very Active Member Force's Avatar
    Nov 2012
    Australia WA Great Southern
    In Australia they have determined that it must be visible from a side view of not less than 40 degrees from both sides. I would further check the laws n your state.
    2" risers, TNT racing TRE, Cobra auto pro tuner, HID ,LED signals, 300/160 Metz, K&N, grips, alarm, pairs done, front mounts, custom face & taco, Mirrors, Gel Seats, Lowered 2", Swamp Works 2 piece chrome swing arm, Velocity Pro 2 into 1, Coastal Moto "Cyclone" 10x18 -4.25.x18, Tricky Air Ride, more to come, hydraulic clutch, Woolich flash, more to come
    Apr 2008
    mass
    Greggs stainless are the best mounts they mount to hub he sell both styles I have the vertical one installed them on both 9's I have owned with no issues also the come with a light too
    Very Active Member jrrose69's Avatar
    Jul 2008
    Brandon, South Dakota
    I prefer my side mount
ID:	281514   Click image for larger version.
    Very Active Member QZephyr's Avatar
    May 2013
    Iowa
    In regards to side mounts and state laws, how would the side mount style affect you riding into a state that requires a fender mount? Wouldn't this give them a reason for you to be pulled over?
    When you do things right, people won't be sure you did anything at all.
    Apr 2011
    JERZEY
    Greggs stainless horizontal side mount, powder coated black.
    Very Active Member Tazdvl's Avatar
    Mar 2014
    Arizona
    I'm using a Baron Custom. The quality of the mount is excellent. However, after installing it per their instructions, I decided to go back and make a few changes. My custom install of the Baron Customs is in this thread:
    https://www.m109riders.com/forums/sho...d.php?t=256281
    Taz
    Taz
    2012 Suzuki Boulevard M109R
    Mar 2014
    Arizona
    Daylight shot of my 9's fat @$$. Getting a lot of mileage out of that picture lately.
    Taz
    Taz
  17. #15
    Jul 2008
    Forney, TX
    Another AZ 9. Pretty soon we might have enough for a group ride. I have been running Gregg's verticle plate for several years and havent had an issue at all in AZ. Have also ridden in NV, NM, TX, AL, MS, WV, & VA and didnt have an issue with the verticle plate either.
    Sent from my SCH-I545 using Tapatalk
  18. #16
    May 2009
    Quote Originally Posted by QZephyr View Post
    I guess they could if they wanted to be ash-hats... They can cite you for improper of license plate. You can possibly fight it based on whatever state laws apply to wherever your vehicle is registered but in the end it will be up to the judge and it might be more to fight it than to pay for the citation.
    WARNING: MY OPINION MAY OFFEND YOU!!!
  19. #17
    Sep 2012
    Long Island, NY
    LOL
  20. #18
    Feb 2012
    Quote Originally Posted by some 9 View Post
    LOL
    Should say....Will..... Not Might.
    Sent from my GT-S7275R using Tapatalk
  21. #19
    Very Active Member Wildman7's Avatar
    Oct 2010
    NW Burbs IL
    Keith fixed your picture and I agree that's the same one that I have
  22. #20
    Sep 2012
    Long Island, NY
  23. #21
    May 2013
    Iowa
    No, you didn't say "Harley"
  24. #22
    Very Active Member Shooter's Avatar
    Jan 2012
    Hillsboro Missouri
    Guy drops a couple H bombs and you guys won't let him forget it. Sheesh........
  25. #23
    Jul 2008
    Forney, TX
    I dont know how that plate doesnt drag when riding the twisties?
  26. #24
    Sep 2012
    Long Island, NY
    It hasn't yet and I take it low.
  27. #25
    May 2013
    Iowa
    Quote Originally Posted by Shooter View Post
    A couple?
  28. #26
    May 2009
    I really like this one... It's for Harley's but perhaps you can make it work with some modification or by tapping a few holes for under the fender mount.
  29. #27
    Apr 2014
    Chesterfield, VA
    I'll pass on that. They might recall it!
  30. #28
    May 2009
    Hey, at least you'll know that you'll get an updated and improved product. Perhaps Suzuki should take a few pointers in order to fix their known issues--What do you say?.
  31. #29
    Member cbw578's Avatar
    Apr 2015
    bronx new york
  32. #30
    Apr 2014
    Chesterfield, VA
    I say if HD can't get a License plate bracket right the first time, there are bigger problems to worry about. That was the point I was making to begin with!
