Tire pressure
Results 1 to 15 of 15
Thread: Tire pressure
    Very Active Member lincoln1003's Avatar
    Jun 2010
    Little Falls, MN
    Default Tire pressure
    I went for a ride last night and my bike feels like it's washing out in the corners never had that problem before, running a Dunlop E3 rear and a Metzler upfront Air pressures are 42 rear 37 upfront ( I know it's low ) my question is with the front tire being 1 pound off of Spec would that make it feel squishy in the corners or do I have something more to be concerned about I will be airing it up to about 40 tomorrow. I am 6 foot 300lbs in case that matters
    Aug 2006
    No it won't. I run around 32 or 33 in both tires on mine to even out tread wear and provide a softer, stickier ride and I have had no handling issues whatsoever...
    Jun 2010
    Little Falls, MN
    Could having 2 different tires cause a problem ?
    Aug 2006
    Quote Originally Posted by lincoln1003 View Post
    That could be...the Metz is probably a softer compound than the Dunny and that could be causing it...
    Feb 2009
    Oklahoma City
    I keep both the front and rear at 42 psi, have the Elite III's. Never had a problem with unusual tread wear or wearing too fast when kept at this pressure.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
    White 2004 Ford Lightning
    Blue/Black 2007 Ford Mustang
    Red/Black 1998 Ford Ranger
    Jan 2009
    Hampton, Ga
    42 psi front and rear here as well.
    -Josh
    Jun 2010
    Little Falls, MN
    I'm not having any issues with tire wear the bike feels lose in the corners .
    Very Active Member Force's Avatar
    Nov 2012
    Australia WA Great Southern
    Would there be any chance of bearing issues or even axel not torqued enough? Just a thought.
    2" risers, TNT racing TRE, Cobra auto pro tuner, HID ,LED signals, 300/160 Metz, K&N, grips, alarm, pairs done, front mounts, custom face & taco, Mirrors, Gel Seats, Lowered 2", Swamp Works 2 piece chrome swing arm, Velocity Pro 2 into 1, Coastal Moto "Cyclone" 10x18 -4.25.x18, Tricky Air Ride, more to come, hydraulic clutch, Woolich flash, more to come
    Very Active Member ausdog's Avatar
    Jan 2014
    Australia
    Is the handling issue something that has been there since purchase, or only a recent development?
    It could be that you need revalving/heavier weight oil and springs in the forks for your weight?
    Jun 2010
    Little Falls, MN
    problems started this year both axels torqued to spec last time they were off . Only 9000 on bike , Dunny was new, Metz was bought used off this site and was like new
    Feb 2012
    I have a 150, So not relevant, But for your Interest, I run 56psi, and my 130 i ran at 48, and it took all the washey out.
    Very Active Member Tazdvl's Avatar
    Mar 2014
    Arizona
    I agree with Skidder. I just had my front replaced with a Dunlop E3 130. They set it at spec, 38psi. Was terrible, washy and felt like it was slipping in the corners. Up your pressure to 42psi, and see how that feels. I think you'll like it.
    Taz
    Taz
    2012 Suzuki Boulevard M109R
    Sep 2014
    Saint Charles, MO.
    Check your triple tree and see if it's a little loose.
    2012 M109R LE Power Commander V, XTRE, K&N intakes and filters, Sideburner, VStream Windscreen, lowering links, Cobra passenger pad
    Member of the Torque and Recoil Club
    Jun 2010
    Little Falls, MN
    Ok so I bought a digital gauge re-checked front was at 36.5 rear was 38 I aired them both up to 42 and it handled great .
  17. #15
    Feb 2009
    Oklahoma City
    Funny what a little extra air will do.
    SILVER 2006 M109R.
    BLACK 2008 B-KING
