riser suggestions
Results 1 to 14 of 14
Thread: riser suggestions
    Jun 2015
    lampman, sk
    Default riser suggestions
    So I have 2"riser extensions on my bike. I'm finding I want them higher, but not closer to me. Basically as I'm set up right now, putting my hands on my mirrors is about where I want to be. Is there a straight riser out there to replace the stock one maybe? Or do I need to look at a new handlebar?
    Jan 2009
    Hampton, Ga
    I have 2 inch risers that go under the base of the riser at the triple tree. They mimic the stock risers so they blend in, and even use the factory base gasket and washer. $100 shipped.
    -Josh
    Very Active Member Glocker23's Avatar
    Sep 2009
    Connecticut
    Those little pieces not the whole piece right. How do u like it. Any pics
    Jan 2009
    Hampton, Ga
    This is what they look like. I love them. They moved the bars up 2 inches and back maybe an inch because of the angle of the triple trees.
    -Josh
ID:	266786   Click image for larger version.
    Jun 2015
    lampman, sk
    Josh, those risers are 2" taller than stock right? Do you know of any that are even taller?
    Sep 2009
    Connecticut
    Website link?
    Jan 2009
    Hampton, Ga
    I don't have any that are taller. I only had them made in two inch.
    Glocker, i had them made. I don't have a website for them.
    -Josh
    Very Active Member DutchM1800R2's Avatar
    May 2014
    Netherlands
    Googled for "m109r riser extensions" for a bit.. there's plenty to be found.
    CustomDynamics has both 1" and 2" extensions, as found here: http://www.customdynamics.com/suzuki...dlebar_Risers_
    From the looks of it I suppose you could stack multiple ones to get more than 2" extension.. as long as you can find bolts long enough to go all the way through. Might look weird though..
    My 0.02
    Jan 2009
    Hampton, Ga
    Those extensions go on top of the risers, pushing the bars closer to the rider. He's looking for extensions tO make the bars go up, not back. That's the reason i had them made.
    -Josh
    May 2014
    Netherlands
    Ah! Makes sense
    Ignore me pls
    Very Active Member crshalladay's Avatar
    Apr 2008
    Massena, NY
    Quote Originally Posted by DutchM1800R2 View Post
    My 0.02
    Do these bring the handlebars back at all? or just up?
    1948 Willys chopped 6 inches on s10 frame with 350c.i. motor.  Air bags in the rear, drop spindles in front.
    Feb 2010
    Quote Originally Posted by crshalladay View Post
    A little of both. Look at the angle your stock risers are at and picture them being 2" longer, as that's all the riser extensions do. So they come back a little more than they come up.
    Sep 2014
    Saint Charles, MO.
    Is there any aftermarket bars available? That would fix the problem without changing the risers.
    2012 M109R LE Power Commander V, XTRE, K&N intakes and filters, Sideburner, VStream Windscreen, lowering links, Cobra passenger pad
    Member of the Torque and Recoil Club
    Jun 2015
    lampman, sk
    Yeah I think bars will be the only way to get what I'm wanting.
